Problem with Graphics Layer
652
05-04-2012 12:21 PM
NigelAlford
New Contributor III
I'm using the graphics layer example and one query works but the second doesn't and I'm stuck on the reason why. Both layers support Querying and the specified query works inside the service. I run a console log for both queries and I'm getting an error message:
ReferenceError
arguments: Array[1]
get message: function () { [native code] }
get stack: function () { [native code] }
set message: function () { [native code] }
set stack: function () { [native code] }
type: "not_defined"
__proto__: Error
 serverapi.arcgisonline.com:14
dojo.Deferred.reject.errback
Below is the code for the map:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html lang="en">
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Multiple Graphics Layers</title>
    <script type="text/javascript"  charset="utf-8" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8compact"></script>
     <style type="text/css">
      html, body
        height: 100%;
        margin: 0px;
        padding: 0px;
        width: 100%;
       .esriSimpleSlider
       div
        height: 30px !important;
        width: 30px !important;
      </style>
    <script type="text/javascript" charset="utf-8">
      dojo.require("esri.map");
      dojo.require("esri.virtualearth.VETiledLayer");
      dojo.require("esri.tasks.query");
      var map, BINGMAPS;
      function init()
        var supportsOrientationChange = "onorientationchange" in window,
          orientationEvent = supportsOrientationChange ? "orientationchange" : "resize";
        window.addEventListener(orientationEvent, function () {
          orientationChanged();
        }, false);
        var initialExtent = new esri.geometry.Extent({ "xmin": -9414173.061, "ymin": 3995118.342, "xmax": -9398289.375, "ymax": 4014748.679, "spatialReference": { "wkid": 102100} });
        map = new esri.Map("map", {extent: initialExtent,wrapAround180: true, logo:false});
        dojo.connect(map, "onLoad", doQueries);
        veTileLayer = new esri.virtualearth.VETiledLayer({bingMapsKey: 'AimF6LphvVcbtQZOyiopeyQT8n-QOTukhwoRZwnzKL1MM0_B1Dfc7ppeKmyPByKp',
     mapStyle: esri.virtualearth.VETiledLayer.MAP_STYLE_ROAD});
     map.addLayer(veTileLayer);
      function doQueries(map)
        //Milepost Query
        var MPQueryTask = new esri.tasks.QueryTask("http://esoc1.nscorp.com/ArcGISProduction/rest/services/EGIS/ENG_MPMARK/FeatureServer/0");
        var MPQuery = new esri.tasks.Query();
        MPQuery.outFields = [ "MPMARKER", "DIVCODE", "CREATEDATE", "ASSET_PK" ];
        MPQuery.returnGeometry = true;
        MPQuery.where = "DIVCODE = '04'";
        //MPQuery.outSpatialReference = map.spatialReference;
        MPQueryTask.execute(MPQuery, MPSymbology);
        //Locomotive Query
        var LocQueryTask = new esri.tasks.QueryTask("http://esoc1.nscorp.com/ArcGISProduction/rest/services/ITGIS/LOCOMOTIVE_LOCATION/FeatureServer/0");
        var LocQuery = new esri.tasks.Query();
        LocQuery.outFields = ["*"]
        //[ "LOC_INIT", "LOC_NUM", "DTM", "FUEL_LEVEL", "ENGINE_ONOFF", "ENGINE_TEMP" ];
        LocQuery.returnGeometry = true;
        LocQuery.where = "ENGINE_ONOFF = '1'";
        MPQueryTask.execute(LocQuery, LocSymbology);
     function MPSymbology(featureSet)
        var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
        symbol.setColor(new dojo.Color([0,0,255]), 1);
        var cityLayer = new esri.layers.GraphicsLayer();
        cityLayer.setInfoTemplate(new esri.InfoTemplate("${MPMARKER}","${*}"));
        map.addLayer(cityLayer);
        dojo.forEach(featureSet.features, function(feature) {cityLayer.add(feature.setSymbol(symbol));
        console.log("MP Query: ", featureSet);
   function LocSymbology(featureSet)
        var Locsymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
        symbol.setColor(new dojo.Color([0,205,0]), 1);
        var LocLayer = new esri.layers.GraphicsLayer();
        LocLayer.setInfoTemplate(new esri.InfoTemplate("${LOC_INIT}","${*}"));
        map.addLayer(LocLayer);
        dojo.forEach(featureSet.features, function(feature) {LocLayer.add(feature.setSymbol(Locsymbol));
        console.log("Loc Query: ", featureSet);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body>
    <div id="map" style="width:100%; height:100%;"></div>
  </body>
</html>
danbecker
Occasional Contributor III
In your locomotive query, you need to change the last line
to:
LocQueryTask.execute(LocQuery, LocSymbology);
think you forgot to change it to the locomotive query task after you c/p it
