Hi
I installed ArcGIS Viewer for Silverlight but got a Compilation Error in my browser when I tried to open/run it.
Any help with this would be greatly appreciated!
Regards
Barry
P.S. The error is copied below, exactly as it appears.
Server Error in '/Builder' Application.
Compilation Error
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error Message: CVT1108: cannot open C:\Windows\TEMP\RES80A4.tmp for writing
Source Error:
[No relevant source lines]
Source File: CVTRES : fatal Line: 0
Show Detailed Compiler Output:
c:\windows\system32\inetsrv> "C:\Windows\Microsoft.NET\Framework64\v2.0.50727\vbc.exe" /t:library /utf8output /R:"C:\Windows\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\builder\cd1cb5b4\cceb6353\assembly\dl3\d7b2a6c1\006296b1_fdcfcc01\ESRI.ArcGIS.Mapping.Builder.Web.DLL" /R:"C:\Windows\assembly\GAC_MSIL\System.WorkflowServices\3.5.0.0__31bf3856ad364e35\System.WorkflowServices.dll" /R:"C:\Windows\assembly\GAC_MSIL\System.ServiceModel.Web\3.5.0.0__31bf3856ad364e35\System.ServiceModel.Web.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\builder\cd1cb5b4\cceb6353\assembly\dl3\c6766081\000834af_fdcfcc01\ESRI.ArcGIS.Mapping.Builder.Server.DLL" /R:"C:\Windows\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll" /R:"C:\Windows\assembly\GAC_MSIL\System.ServiceModel\3.0.0.0__b77a5c561934e089\System.ServiceModel.dll" /R:"C:\Windows\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll" /R:"C:\Windows\assembly\GAC_MSIL\System.IdentityModel\3.0.0.0__b77a5c561934e089\System.IdentityModel.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\builder\cd1cb5b4\cceb6353\assembly\dl3\9c517171\007379a4_fdcfcc01\ESRI.ArcGIS.Mapping.Builder.Common.DLL" /R:"C:\Windows\assembly\GAC_64\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll" /R:"C:\Windows\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll" /R:"C:\Windows\assembly\GAC_64\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll" /R:"C:\Windows\assembly\GAC_64\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll" /R:"C:\Windows\assembly\GAC_MSIL\System.Runtime.Serialization\3.0.0.0__b77a5c561934e089\System.Runtime.Serialization.dll" /R:"C:\Windows\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll" /R:"C:\Windows\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a\System.Web.Mobile.dll" /out:"C:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\builder\cd1cb5b4\cceb6353\App_Web_default.aspx.cdcab7d2.xponcmjk.dll" /D:DEBUG=1 /debug+ /win32resource:"C:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\builder\cd1cb5b4\cceb6353\nuzbooo7.res" /define:_MYTYPE=\"Web\" /imports:Microsoft.VisualBasic,System,System.Collections,System.Collections.Specialized,System.Configuration,System.Text,System.Text.RegularExpressions,System.Web,System.Web.Caching,System.Web.SessionState,System.Web.Security,System.Web.Profile,System.Web.UI,System.Web.UI.WebControls,System.Web.UI.WebControls.WebParts,System.Web.UI.HtmlControls "C:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\builder\cd1cb5b4\cceb6353\App_Web_default.aspx.cdcab7d2.xponcmjk.0.vb" "C:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\builder\cd1cb5b4\cceb6353\App_Web_default.aspx.cdcab7d2.xponcmjk.1.vb"
Microsoft (R) Visual Basic Compiler version 8.0.50727.5420
for Microsoft (R) .NET Framework version 2.0.50727.5448
Copyright (c) Microsoft Corporation. All rights reserved.
CVTRES : fatal error CVT1108: cannot open C:\Windows\TEMP\RES80A4.tmp for writing
vbc : error BC31019: Unable to write to output file 'C:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\builder\cd1cb5b4\cceb6353\App_Web_default.aspx.cdcab7d2.xponcmjk.dll': The specified image file did not contain a resource section.
Version Information: Microsoft .NET Framework Version:2.0.50727.5448; ASP.NET Version:2.0.50727.5456
