Calculate US National Grid coordinates for a point feature class
3057
05-17-2012 06:36 AM
GlennKammerer
Does anybody have a script that can calculate the US National Grid coordinate value for all points in a feature class? Apparently there is some functionality for the US National Grid built into ArcMap 10, but I have yet to run across any tools, menus, wizards or toolboxes that have anything to do with this.
Any help or suggestions greatly appreciated.
AndrewChapkowski
You can use this script: http://code.google.com/p/opcon/source/browse/trunk/lib/CoordConverter.py to get the coordinates into MGRS or USNG coordinates (they are the same thing).
Sample use:
>>>    import CoordConvertor
>>>    ct = CoordConvertor.CoordTranslator()
>>>    print ct.AsMGRS([36.279707,-77.266846],4,False)
18S TF 96401735
Couple this module with the arcpy.UpdateCursor() you can then insert each value into your column.
You can also try to follow the instruction found here: http://blogs.esri.com/esri/arcgis/2011/01/05/converting-and-displaying-coordinates-in-arcgis-10/
Hope this helps.
GlennKammerer
Thanks!! Will try this post haste!
RichardButgereit
See the EditorTracker add-in here -- FloridaDisaster.org - US National Grid
Add X,Y, and USNG fields to your feature class, and at every add/update, coordinates are calculated.
