Error Code 4004
1730
06-05-2012 01:56 PM
TanyaOwens
Occasional Contributor III
I get the following error when I try to use the navigation tool:
An unhandled exception ('Unhandled Error in Silverlight application)
Code: 4004
Category: ManagedRuntimeError
Message: System.NullReferenceException: Object reference not set to an instance of an object.
Any suggestions?
JoeHershman
MVP Regular Contributor
Have you confirmed that the Map property on the Navigation tool is set correctly?
-Joe
JoeHershman
-Joe
TanyaOwens
Your right - I forgot to add Map ="{Binding ElementName=MyMap}". I guess that is important. 😮 Thanks for your help.
ZhanpingShi
Hi folks,
I encountered a similar issue which I started to run the Silverlight Application, it always shows somehow a security issue and feature layer info issue message, please take look at the attached screen shot, if you have any ideas to fix the problem, thank you in advance.
Zhanping Shi
