Annotation using ArcGIS for AutoCAD Attributes
Discussion created by phdjoe on Jun 6, 2012
Is there away to use the schema attributes in an AutoCAD annotation template?  I can find the ArcGIS for AutoCAD attributes listed in the Annotation Template > Block Editor> Edit Annotation Text > Value Field > Expression Chooser under Object Properties > AcDbEntity > MLINE > feature class > attribute, but the values are not pulling through to the annotation. The Value field in the annotation text window states: ^AcDbMLINE.Rooms.Type where rooms is my feature class.  The annotation returns the TAG instead of the Value.
Any help is appreciated
