51 Replies Latest reply on Apr 23, 2015 9:36 AM by vsfoote
    ArcGIS Desktop 10.1 License manager concurrent use invalid hostname
    langleyfan
      I've upgraded to ArcGIS Desktop 10.1. Uninstalled both old versions of the license manager and desktop then installed version 10.1.
      I'm running license manger on another server with a concurrent use license. All diagnostics on the license manager check out good but when I try to define the license manager for a desktop installation it responds with an invalid hostname error. I can ping the hostname and it resolves. I've even temporarily disabled Windows server 2003 firewall.
      Any ideas?
      Dave
        • Re: ArcGIS Desktop 10.1 License manager concurrent use invalid hostname
          msimmons75
          Did you install the 10.1 license manager?  I don't think the license manager used with version 10 will support 10.1, however the license manager with 10.1 WILL support 9.x and 10x versions.
            langleyfan
            Sure did. Status says it's running.
              rastrauch
              I too am having issues with ArcGIS Administrator 10.1 (final) attaching to the 10.1 (final) License Manager when trying to use the IP address of the host.  If I use the LM server name it works.  We have users that are off the network that need to use the IP address, so this is critical for us.
              With 10.1 pre-release, the IP address worked fine.  A desktop 10.0 sp3 machine still can attach to 10.1 final LM using the IP.    So, I don't think it is a problem with the LM, but the Desktop release maybe?
              Dave, are you pointing to the machine name or IP?  I have an incident in to tech support on this, so if it's the IP, I'll make sure to let you know what I find out.
                rastrauch
                This is an update to my issue with using IP addresses for Desktop 10.1 accessing the License Manager 10.1
                This is confirmed as bug NIM081698.  Hopefully they will be reviewing it right away.  It seems to come down to the Desktop Administrator not accessing or updating the registry correctly.  It also seems to ignore the ARCGIS_LICENSE_FILE variable right now.  If you are brave, this can be fixed with a manual registry edit, but not necessarily a good deployment option.  Hopefully this is something they can patch quickly, or at least give those of us that need it the registry item effected for the various OS.    BTW - this only seem to be with Desktop 10.1,   previous versions still update with Desktop Admin or the variable just fine (I prefer the variable for users outside or network/firewall, btw).
                  ksjosh82
                  I have run into this issue as well, I tried to get on Esri Chat and they are apparently swamped and I wasn't able to get a tech but reception forwarded the request on.  This is a MAJOR bug so hopefully they do find a patch soon.
                    dvela
                    I'm having the same issue. Except my license manager isn't giving out any licenses! I tried connecting an ArcMap 10 client and it refuses.
                      ksjosh82
                      Hey, I thought I'd point out what Support discovered was my case, my Firewall was not allowing the license manager to run properly.  We disabled the firewall and and it worked.  Obviously, I can't leave it disabled so some exceptions will have to be made, I haven't done that yet, waiting for IT to do it, so I'm not sure how succesful it is.  Support directed me to have IT open a few ports.  If you are interested and want more info, give me your email and I will forward what she sent to me.
                        dvela
                        Don't think its firewall issues since I had v10 license manager on there and it was working. But I'll give it a try.
                        Thanks, I sent you my email.
                          isaac@clovis
                          Try the fully qualified domain name.  This sounds like a DNS issue, also try the IP address of the license server.
                            rastrauch
                            The NIM (bug) refers to trying to attach to the LM using the IP address instead of the server name.   We already have a port open that we have used with all the previous releases of LM/desktop.  I have all users set this in their system variables.
                            All 9.3 and 10.0 clients are still able to use this set up and attach to the 10.1 LM.  The problem is introduced with the 10.1 desktop client.   It ignores the system variable that is set.
                            A value can be set in the registry that can override this, and we (tech support and I) have had luck with including the info in the hosts file, but these still only working when on the network.   When we really need to us the IP is for those user (many) that are not attched to the network (remote offices and firld camps. We haven't been able to get that to work yet, even with the normal open port method that has worked before.
                            I know the ESRI is definitely working on this now, but if it's an issue for you, have them add you to the NIM.  When I escalated it, I could only list the users in my org as how many user it will affect, since that's all I could speak for....but my guess is there are a lot of us out there.
                              dvela
                              Yup, tried all of that too, still no worky.
                                isaac@clovis
                                Only work around I see is if they have laptops.  Check out licenses to them for now and fix the solution, then set it up correctly later.
                                  dvela
                                  I'm just going to wait until ESRI patches this.
                                    vsfoote
                                    Becky,
                                    ...The problem is introduced with the 10.1 desktop client.   It ignores the system variable that is set.
                                    A value can be set in the registry that can override this, and we (tech support and I) have had luck with including the info in the hosts file, but these still only working when on the network. ...
                                    Would you please share what registry value you are setting, and what value you've had to add to the host file.
                                    Perhaps you also could post up a screen capture of the NIM 081698 item. It seems to be locked down and unavailable to the rest of us users.
                                    Stuart
                                      rastrauch
                                      Becky,
                                      Stuart
                                      Hi Stuart,
                                      NIM081698 "When using the IP address from the ArcGIS administrator in 10.1, connection to the License Manager fails. Error:" <IP_address> is an invalid hostname. Please enter a valid hostname."
                                      Sorry about not posting something already, but I was hoping for a real fix. Keep in mind that none of these workarounds fixed the problem for my users outside our firewall, even trying all diferent combination with our open port (that works with 10.0 and 9.x clients). So even though they have "workarounds" listed, they are only partial fixes for internal IP connections, and the NIM is still OPEN. I also have the ARCGIS_LICENSE_FILE system variable set, which is what made it work with the previous clients, but it didn't seem to help 10.1 at all. Below are the workarounds listed with the NIM (with my comments)
                                      I would suggest modifying the HOSTS file first since that seemed to work just as well as changing the registry key.
                                      [INDENT]Workaround 2:
                                      Add the IP address of the License Manager to the hosts file under
                                      C:\Windows\System32\drivers\etc
                                      <ip address> server_name
                                      # localhost name resolution is handled within DNS itself.
                                      # 127.0.0.1 localhost
                                      # ::1 localhost
                                      10.10.10.100 PETER (BTW -this is the only line to add, for those not familiar with the hosts file)
                                      Then use the name "PETER" for the license server even if this is not the License Manager hostname.[/INDENT]
                                      --Note: I found that the name can be anything, as long as if starts with alpha character, so using the sample IP above
                                      <indent>10.10.10.100 AV10.10.10.100</indent>
                                      -- with the name being "AV10.10.10.100" would work just as well as their "PETER" sample. So keep it logical if not the machine name.
                                      The registry key/value listed was for a 64 bit server (my test machine) so path names for this may vary (as the hosts file location could vary slight depending on OS).
                                      [INDENT]Set the License Manager through the registry
                                      HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ESRI\License10.1 >LICENSE_SERVER value to
                                      the IP address.[/INDENT]
                                      I'll check with tech support this morning to see what the status is, and will add a status update later today. At a minimum, I've asked for a KB article covering the registry key for each of the supported OS, if this does end up working some how.
                                      Becky
                                        vsfoote
                                        Becky,
                                        Thanks for the additional info.
                                        Just verified that the ARCGIS_LICENSE_FILE variable is not working with the 10.1 Final release clients. Which makes all of the Desktop 10.1 ArcGIS Administrator tool (anything dependent on ArcGISAdmin.exe and ArcGISAdmin_libFNP.dll or configured in the C:\Program Files (x86)\Common Files\ArcGIS\bin folder) suspect for now.  ARCGIS_LICENSE_FILE was functional for the 10.1 Prerelease.
                                        I have used the hosts file in the past, and notably recently on the license server to allow it to talk to itself via 127.0.0.1 loopback--but it presents a challenge since the average user will not have write permissions to the System32 folder.
                                        But we here, and others, are able to address the license server by IP without issue--setting the LICENSE_SERVER value either with a registry editor session or using ArcGIS Administrator. Both <port>@<IP>, or @<IP> formats work in addition to using a @<FQDN> based address. That kind of suggests to me that your DNS server and possibly NAT/PAT isolation (i.e. Firewall) of your license server may be at least some of the the issue for your internal users and for users outside your network not being able to route their FlexNet license requests via IP--do you provide VPN service they can tunnel in through? Once on VPN they should receive internal DNS across the tunnel.
                                        Stuart
                                          rastrauch
                                          But since we are able to address the license server by IP without issue--setting the LICENSE_SERVER value either with a registry editor session or using ArcGIS Administrator. Both <port>@<IP>, or @<IP> formats work in addition to using a @<FQDN> based address. That kind of suggests to me that your DNS server and possibly NAT/PAT isolation (i.e. Firewall) of your license server may be at least some of the the issue for your internal users and for users outside your network not being able to route their FlexNet license requests via IP--do you provide VPN service they can tunnel in through? Once on VPN they should receive internal DNS across the tunnel.
                                          Stuart
                                          (Hopefully this isn't a repeat....lots of blue screens today from my DVD writer and I think it crashed before I sen thte last response was posted)
                                          Stuart, I don't think having all our users on VPN is an option, although I am not a network administrator.  I do know that our <open port>@<ip> worked for 9.x and 10.0, and I also believe it worked with 10.1 beta, but not sure I ever tested it with pre-release.  I'm also pretty sure that nothing has change with our DNS or firewall in the past couple weeks.  The port we've been using still is open or I would have heard a lot of complaints by now.
                                          I am able to connect using the <ip> inhouse if I modify the hosts file, so it's really the external users (the majority) that I need a workaround for. With our very sluggish network connections in Alaska, we have been using the <port>@<ip> and ARCGIS_LICENSE_FILE variable options even for those on the state network but in remote communities...it seems to speed up the connection to the license manage to those office (vs. using just the LM server name).  Other users MUST connect that way because they are on private ISPs or working from temporary field camps...or are travelling.
                                          (I haven't heard back from tech support today, but I noticed my incident was "closed".   i'm not sure if it's policy to close the inc. if a bug/NIM is spun off or not, but it definately isn't solved yet that I can tell.)
                                            blakkur-esristaff
                                            Becky,
                                            Stuart
                                            Hi Stuart,
                                            We are not able to reproduce the problem with the ARCGIS_LICENSE_FILE environment variable.  Can you tell me how you have it configured?
                                            Badri
                                              vsfoote
                                              Badri,
                                              Registry Edit to Not_Set or assign a nonsense entry for LICENSE_SERVER value in either of these keys:
                                              [INDENT](64 bit OS)
                                              (32 bit OS)
                                              HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\License10.1[/INDENT]
                                              Create an ARCGIS_LICENSE_FILE environment variable. Either from Start --> Computer --> Properties --> System Properties --> Advanced --> Environment Variables --> System Variables -- New...
                                              or directly with registry edit in the
                                              [INDENT]HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment [/INDENT]
                                              key creating a New String Value. Then modify with the <port>@<FQDN>, or @<FQDN>, or <port>@<IP>, or @<IP>.
                                              Then launch ArcGIS Administrator -- the ARCGIS_LICENSE_FILE variable just created will show the value entered. And from Desktop --> Availability if the ARCGIS_LICENSE_FILE value is being resolved, the panel should show the full pool. Unfortunately it is not honored, and the Availability panel will show only the unauthorized/unactivated seat with no license or available seats. See attached...
                                              Stuart
                                                vsfoote
                                                Badri, et. all
                                                Further to the ARCGIS_LICENSE_FILE not being honored by libFNP.dll components, a LM_LICENSE_FILE environmental variable with an ArcGIS License Server host entered is also not being processed by the Desktop 10.1 (final) licensing.  Same result as with the Esri specific ARCGIS_LICENSE_FILE environmental variable.
                                                Stuart
                                                  blakkur-esristaff
                                                  The ArcGIS Administrator currently only displays available licenses from a license manager specified in the utility, it does not read the one defined in the environment variable.  However when launching ArcMap the license is picked up from the LM defined in the environment variable.  We can definitely look into making the ArcGIS Admin. display the Availability of the LM defined in the environment variable as well.
                                                  Badri
                                                    vsfoote
                                                    Badri,
                                                    OMG, you are absolutely correct! For some reason I did not even try launching ArcMap with the LICENSE_SERVER not set but ARCGIS_LICENSE_FILE variable pointing to a valid server. Rather, I just read zeros in the Availability panel and didn't try.
                                                    I've now verified that both the ARCGIS_LICENSE_FILE and the LM_LICENSE_FILE do function as they always had--ArcGIS 10.1 will launch and consume license without fuss using the variables.
                                                    Of course, being unable to use ArcGIS Administrator, borrowing against the Environment Variable set license pool is going to be a little difficult.
                                                    So yes the ArcGIS Administrator GUI needs some additional work!
                                                    And, while looking at that--can you revisit your validation code used in the License Manager (for Concurrent Use software products): Change.. object.
                                                    In the ArcGIS Administrator panels, would expect we should be able to enter a valid license server by at least its Dot4 IP address. We should not to have to use the workaround of a manual registry edit to enter an IP as the LICENSE_SERVER value. Remains to be seen how IPv6 starts to impact things as it becomes more widely used.
                                                    So, perhaps include a check box, or radio button, on the panel to accept the exact value entered gets written to the registry LICENSE_SERVER value--without attempting to resolve first via Host file or DNS lookup, and also to bypasses verification of entry is an active ARCGIS Vendor FlexNet license pool.
                                                    Think doing that would help with FlexNet Publisher latency or Firewall issues causing timeouts during setup.
                                                    Stuart
                                                      rastrauch
                                                      That kind of suggests to me that your DNS server and possibly NAT/PAT isolation (i.e. Firewall) of your license server may be at least some of the issue for your internal users and for users outside your network not being able to route their FlexNet license requests via IP
                                                      Stuart
                                                      Stuart, you may have been right about DNS issues for our external 10.1 clients.  It didn�??t seem likely since the 9.x/10.0 clients worked just fine with our normal setup.  But yesterday IT fixed some issues with our DNS, so maybe that WAS part of the problem.  Unfortunate timing.   I'm trying it from home again today and having better luck.
                                                      I know much of this is a repeat of the thread above, I but want to summarize what has worked for me now, in case it helps other.
                                                      OUR NEED: I like to use the <port>@<ip> whether within the firewall (in building or in a remote office) or outside the firewall, 1) for consistency for user setup/support, 2) because that specifying the <port>@<ip> seems to speeds up LM connections, especially noticeable for remote users, and 3) because the open <port> portion is required for those outside the firewall.
                                                      ISSUE: with the 10.1(final release, June 2012):
                                                      1) ArcGIS (Desktop) Administrator will not currently accept an IP address for the license manager. Error �?? xxx.xx.xxx.xxx is an invalid hostname. Please enter a valid hostname.�?�      It WILL accept machine name (within firewall and/or if fully-qualified-domain-name accessible outside firewall)
                                                      2) ArcGIS Administrator may be ignoring the ARCGIS_LICENSE_FILE system variable.  At aminimum, the �??licenses available�?� are not displaying correctly, as Badri confirmed above.
                                                      NEED to come up with a common solution for all our users that has minimum manual tweaking, flexible enough for swapping to other LMs when needed, and doesn�??t run into security/admin roadblocks\restrictions for our staff,
                                                      In our case, we already have the open <port> and license manager configured http://resources.arcgis.com/en/help/install-guides/license-manager/10.1/index.html#//00790000000w000000
                                                      License manager is working correctly, so this just deals with the client machine end.
                                                      Set both the ARCGIS_LICENSE_FILE variable AND the registry value as shown by Stuart, but use the <port>@<ip> for both values
                                                      <<MODIFIED by rastrauch>>
                                                      1. Registry Edit for LICENSE_SERVER value in either of these keys, set value to your <port>@<ip>  or just the <ip> is you don�??t need the port
                                                      (64 bit OS)
                                                      (32 bit OS)
                                                      2) Create an ARCGIS_LICENSE_FILE environment variable. Either from Start --> Computer --> Properties --> System Properties --> Advanced --> Environment Variables --> System Variables -- New...
                                                      key creating a New String Value. Then modify with the <port>@<FQDN>, or @<FQDN>, or <port>@<IP>, or @<IP>.    <<can include multiple entries with ; (semi-colon)>>
                                                      By setting both, I was able to see the available licenses (although maybe not the first time I started ArcGIS Administrator after the updates).  To actually change the LM to a different server (e.g. our license checkout pool), I had to modify the LICENSE_SERVER registry value again.
                                                      We have a VBScript (.vbs) file that allows us to create/modify the ARCGIS_LICENSE_FILE and can share that if anyone is interested (will attach as .txt file). I�??m hoping to have one to help with setting the registry soon until this gets fixed on the ArcGIS Administrator client end.
                                                      BTW �?? although the editing the hosts files did allow me to access the LM machine internally with an alias, it did nothing for machines that couldn�??t see the IP address and machine name already.  So the above solution is what seems to work best at this time for us.
                                                      I hope this is helpful for others.
                                                        rastrauch
                                                        UPDATE - simpler non-evasive workaround when using IPs for license manager:
                                                        By accident, one of my colleagues discovered that putting a comma after the entry in ArcGIS Desktop administrator works, and actually changes the registry key.  The system variable ARCGIS_LICENSE_FILE may still need to be set up before it recognizes the new value IP.
                                                           1. Create an ARCGIS_LICENSE_FILE environment variable.
                                                        [INDENT]XP -    From Start --> My Computer (right-clight for) --> Properties --> Advanced --> Environment Variables --> System Variables -- New.      Variable Name:   ARCGIS_LICENSE_FILE    Variable Value: your LM info <port>@<FQDN>, or @<FQDN>, or <port>@<IP>, or @<IP>. <<can include multiple entries with ; (semi-colon)>>[/INDENT]
                                                        [INDENT]Win7 -    From Start --> Computer (right-clight for) --> Properties --> (on Left) Advanced System Settingses --> Environment Variables --> System Variables -- New.      Variable Name:   ARCGIS_LICENSE_FILE    Variable Value: your LM info <port>@<FQDN>, or @<FQDN>, or <port>@<IP>, or @<IP>. <<can include multiple entries with ; (semi-colon)>>[/INDENT]
                                                           2. Launch ArcGIS Administrator -- the ARCGIS_LICENSE_FILE variable just set should appear at the bottom of the main page.  In License Manger field, enter your  "<port>@<ip>,"          (without the quotes, but including the comma).  for example:
                                                        1234@456.78.901.23,
                                                        If it still gives and error about being an invalid host, check the variables in step 1 again.   It shouldn't need a reboot, but that never hurts either.
                                                        Since this did update the registry, the number of licenses should also show correctly.
                                                          vsfoote
                                                          Becky,
                                                          I think you've solved it!
                                                          [INDENT]I wanted to strike this comment while editing, but Esri's vBulletin based forum is not taking the code. -vsf
                                                          [S]But, rather than an ending "comma", it has to be a "semi-colon" to close the License Manager field entry when using IP in ArcGIS Administrator --> Desktop panel.[/S]
                                                          [S]Using the closing semi-colon the change button will honor IP addresses, with or without a <port>@ specification.  And if I remember FlexNet Publisher documentation, the "semi-colon" is the field separator between license pools for Windows, while the "comma" is the field separator for Unix/Linux.  Anyhow, on my Windows systems the "semi-colon" works, "comma" does not.[/S][/INDENT]
                                                          Also, believe use of the LM_LICENSE_FILE, or ARCGIS_LICENSE_FILE will still not be read by ArcGIS Administrator for borrowing and such--per Badri Esri has to change the interface and release a patch for that. Simple test to prove it to yourself--clear the License Manager entry. Set ARCGIS_LICENSE_FILE with or with out "comma, or semi-colon" -- check availability from ArcGIS Administrator -- any show? If not ARCGIS_LICENSE_FILE variable is not being read.
                                                          Stuart
                                                            rastrauch
                                                            Thanks Stuart.  Semi-colon makes more sense, and I'll give that a try tonight (outside the network).  .....I just tried the semi-colon within the network where the comma worked....semi-colon doesn't work for me.  -ras  note2:  using both the comma followed by a semi-colon worked -ras
                                                            Just got word from esri that the fix in in the code for 10.1 SP1 (no release date given, and I didn't ask...).  So, that may break our workarounds.    :eek:
                                                            @stuart - did you say you received a patch from Badri so we don't have to wait for the SP1?
                                                              vsfoote
                                                              Becky,
                                                              Sorry for confusion.  No, no patch yet from Badri--just that they are looking at handling the ARCGIS_LICENSE_FILE variable within the ArcGISAdmin.exe utility.
                                                              And, I just checked on a Desktop 10.1 client the "comma" is the correct terminator to use in the field!
                                                              Realized that in making my earlier comments with the "semi-colon" I was at a 10.0 client--Duh!  -- So "comma" for now with 10.1, but "semi-colon" would be more in line with FlexNet Publisher practices--and the problem remains how Esri has coded the field validation for the ArcGIS Administrator.
                                                              Stuart
        rastrauch
        Just got word that the patch is now available.  It fixed my issues when using <port>@<ip> and/or <ip> for license manager.  No more comma needed.
        http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=194&MetaID=1888
        Answer:   Apply the patch to ArcGIS 10.1 release.
        vsfoote
        So, takes about 6 minutes to run the patch--lots of Microsoft Installer thrash.
        But, applying the patch does resolve problems with entry of an IPv4 --dotted.quad--field validation of the License Manager entry.
        "COMMA" no longer necessary!
        And, it handles a translated "::ffff:123.123.123.123" IPv4 so assume it correctly handles the various IPv6 notations.
        The <port>@ notations are solid as well.
        This is good :D
        Stuart
        bubbahey25
        I haven't read all the responses, but if you can connect to the machine with the License Manager and you are using a Firewall, that's your issue. See: http://support.esri.com/en/knowledgebase/techarticles/detail/38481
        vsfoote
        @bubbahey25,
        Welcome to the fray, but please do read entire threads before jumping in. You'll see that in this case this was an issue with the Desktop 10.1 ArcGIS Administrator utility that required Esri to issue an out of cycle patch to repair.
        Stuart
        bubbahey25
        thanks! My bad as the cliche goes. Although I do hope users read the article I posted, it is a common problem (and easy solution) for people using License Manager
        when going through a Firewall. Also works for 10.1 by the way
        danielri
        When you upgraded the services.txt file at C:\Program Files\ArcGIS\License10.1\bin (or C:\Program Files (x86)\ArcGIS\License10.1\bin) will be overwritten. This file contains any customizations for port numbers you may have done opened. After adding port numbers into your services.txt file it should look similar to this.
        SERVER mylicense server ANY 27004
        VENDOR ARCGIS PORT=1234
        INCREMENT ACT ARCGIS 1 permanent 1 0CxxxxfffffBxxxx6 \
        vendor_info=xxxxCAPxxxxfffffff
        In the above example we are locking the vendor damon to port 1234 and the TCP port is locked to 27004.
        Note this was issue was first written about in ESRI KB 26134 for ArcGIS 8.x and 9.x.
        Ozplanman
        Just wanted to saythanks to the people who put so much effort into fixing this.  I added a semicolon after our licence server name in the registry entry for the licence server and it worked!  So simple!  I have now run the patch (but I've left the semicolon there!)
        Thanks Becky and others!  Well done!  :D
        Oz.
        [INDENT][/INDENT]
        1234@456.78.901.23,
        rastrauch
        Oz.
        [INDENT][/INDENT]
        Thanks @Ozplanman  It's nice to know that the semicolon doesn't break it after the patch.
        Since the Admin patch actually does fix the problem though, for my users, I've been skipping the semicolon part altogether now and tell them them during the LM setup during install of 10.1 to:
        1) say they will set up the LM later,
        2) apply the patch [URL="http://support.esri.com/en/downloads/patches-servicepacks/view/productid/194/metaid/1888"]10.1 Admin patch]
        3) then go back into ArcGIS Administrator to point to your license manager.
        You pretty much mentioned that in your note, but with the quote, just wanted to make sure people knew they don't have to put the comma or semi-colon if they follow the 3 steps above.  But, as you pointed out, it doesn't seem to break it so either way should work.
        Since service pack 1 is due out any day now, this may change things, but my guess it will just replace the need for the Admin patch unless it does a complete uninstall/reinstall.....however, since the 10.0 (final) usually needs to be installed before a SP, it may still come into play.  Guess we'll have to wait and see.  :)
        Ozplanman
        Hi Bek and others,
        Well this is a tad annoying...one of our staff has installed 10.1 on a Win 7 machine and we've run the patch and it still stubbornly refuses to find the licence server...colons, semicolons, commas and left handed wingnuts notwithstanding!  Has anyone else found this?  We use a server name not an IP address and it works fine on my machine.  Another staff member found that waiting a day or two seemed to get around the issue.  Does the server need a reboot?
        Oz.
        [PHP][/PHP]
        RachelB
        Bubbahey,
        I'm having trouble locating the service.txt file in 10.1, can you give this exact path?
        Rachel
        vsfoote
        Rachel,
        The service.txt configuration file is installed by default as a part of the the ArcGIS 10.1 License Manager. The default installation location is C:\Program Files\ArcGIS\License10.1\bin, but could have been changed to another directory during installation.
        See this 10.1 specific help: http://resources.arcgis.com/en/help/install-guides/license-manager/10.1/#/Configure_the_ArcGIS_License_Manager_to_work_through_a_firewall/00790000000w000000/
        Stuart
        jafar.alkhatib
        thank youuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
        msilin-esri-cis-ru-esridist
        First of all, thanks to everyone for your valuable input!
        Secondly, the ArcGIS Admin patch definitely helps to resolve the issue:
        However, what I've noticed was that even with the patch installed on the client side, the client would still get an 'Invalid Host Name' message unless there was a port specified in the 'service.txt' for the ARCGIS daemon on the server side.
        Consequently, the aforementioned patch in conjunction with specifying the ports for LMGRD and ARCGIS daemons in the 'service.txt' file resolved the issue.
        Client: WinXP; Server: Win2008 R2
        Max
        cRios
        The ArcGIS Administrator does not resolve this Issue!
        The solution is doing that is here described
        Then you will to configure the exceptions ports on Server's firewall and finally the client reads the license.
        Carlos Rios
        mnshir
        Hello All,
        Great support here but I still have not found the ultimate solution.
        I am running LM 10.0 on the server and will a client ArcGIS 10.0 be able to make the connection to the server to read the license file or will the server LM has to be upgraded to 10.1 as well?  If yes, then will the LM 10.1 on a server have an affect where the ESRI software there is 10.0?  I presume, if it is 10.1 then 10.0 and 9.3 ArcGIS client will be able to reach the license and read it.
        My error message is already giving me the solution when it states  "Incorrect version of LM running on the server" My question is if I update it will it create problems for those running 9.3 and 10.0 and connected to the server to access the licenses?
        mnshir
        bubbahey25
        I would  upgrade license manager to 10.1 10.1 LM can service licenses for 10.1, 10.0 and 9.3
        mnshir
        Thank you for the reply and I will upgrade my LM from 10.0 to 10.1 but the error message states to connect to a license manager running FlexLM version 11.10.  Will updating that have any negative consequences?
        vsfoote
        Mohammad,
        The 10.1 SP1 installs the FlexNet Publisher 11.10.1  builds of flexlm components. And Esri's work on the GUI has resolved a number of issues with borrowing and status. The ArcGIS 10.0 seats, and any new/upgraded ArcGIS 10.1 seats will support license check out by the older 9.x build Desktop installations.
        ArcGIS 10.1 SP1 License Manager
        Version
        FLEXnet Licensing v11.10.1.0 build 99220 i86_n3 (lmgr.lib), Copyright (c) 1988-2012 Flexera Software LLC. All Rights Reserved.
        But once upgraded to ArcGIS License Manager 10.1 sp1, you may decide to install the current Flexera lmgrd, lmutil & lmtools release (11.11.1.1 builds) and use those. Downloadable from Flexera here.
        Current Flexera FlexNet Publisher builds
        Version
        FlexNet Licensing v11.11.1.1 build 120142 (ipv4) i86_n3 (lmgr.lib), Copyright (c) 1988-2013 Flexera Software LLC. All Rights Reserved.
        Stuart
        commonman
        I have had this problem with 10.1 and 10.2.1 versions of license manager.  My fix is disabling the Microsoft 6to4 Adapter on windows 7 pc's.  it is in device manager, view hidden devices\network adapters.  Once this is disabled the pc can see the license manager
        pburg_gis
        I ran across this same problem as well and I opened ports 27000 and 64595 in the firewall of the machine that hosts the License Server.  That seemed to do the trick.
        Ian
