Geocoding apartments and getting parcel polygons.
1137
05-12-2010 09:57 AM
ShaneLim
I have two questions actually. I have addresses that have unit numbers at the end. Such as 910 Main st ste 220. What locator do I use? I downloaded the single address with unit but it wants a unit field in the table to geocode and I only have one address field.
Secondly when I geocode my single address parcel locator I get a point shapefile. Is there a way to get the parcel polygons as my result?
Shane
Tags (3)
JoeBorgione
You'll need to parse out the apartment number of suite number of your address field. That's pretty typical when geocoding; getting the address data into a form your locator needs.
As far as getting a polygon as a result; never heard of that.  Geocoding is the process that takes non-spatial tabular data and  creates a discrete x,y location (point feature) by virtue of interpolating an address against some sort of spatial reference, be it a street, parcel, or address point.
ShaneLim
Thanks Joe,
I was hopeing to avoid having to modify the source address table and instead just create a different locator from my parcel data.
I can always join back to the parcel layer with the referenceID field.
Shane
ShanaBritt
Shane:
Does the parcel data have the unit elements broken up in to separate fields? If so then if you have version 10.3+ you can use the US Address - Single House Subaddress style to create the address locator then geocode your table of addresses that have the full address "910 Main st ste 220" in a single field against the parcel based locator. Based on your reply back to Joe I wasn't sure how either the parcel reference data or input address table were formatted. A screen shot would clarify this.
-Shana
JoeBorgione
Had the original post been more current I would have replied much the same way you did with respect to the new locators now available.  Goodness...  Six year ago; how the time gets by us....
