UpdateLayer Assertion Error
2730
07-02-2012 08:27 AM
AllenSmith
Greetings.
I am writing some code to clip a soils layer based on a selected boundray polygon and want the clipped soils layer "SoilsClip" to have the same symbology and label properties as the source layer "Soils".  i am using the UpdateLayer command and keep getting an Assertion Error.  Please provide any help you can.  Thanks.
#Import modules
import os
import sys
import arcpy
#Set Map Document
mxd = arcpy.mapping.MapDocument("Current")
#Set Overwrite Option
#Create Map Layer
arcpy.MakeFeatureLayer_management("Boundary", "Boundary_Selection.lyr")
#Add Boundary Selection Layer to Layers Data Frame
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
addLayer = arcpy.mapping.Layer("Boundary_Selection.lyr")
arcpy.mapping.AddLayer(df, addLayer)
#Set Boundary Selection symbology
SymbologyLayer = ("Boundary")
lyr = ("Boundary_Selection.lyr")
arcpy.ApplySymbologyFromLayer_management (lyr, SymbologyLayer)
#Set Layers data frame extent and scale
lyr = arcpy.mapping.ListLayers(mxd, "Boundary", df)[0]
df.extent = lyr.getSelectedExtent(False)
df.scale = df.scale * 1.15
#Refresh map to show changes
arcpy.RefreshActiveView()
arcpy.RefreshTOC()
#Clip Soils layer, **goes to default gdb**
arcpy.Clip_analysis("Soils", "Boundary_Selection.lyr", "SoilsClip")
#Insert Layer below Boundary_Selection
refLayer = arcpy.mapping.ListLayers(mxd, "Boundary", df)[0]
insertLayer = arcpy.mapping.Layer("SoilsClip")
arcpy.mapping.InsertLayer(df, refLayer, insertLayer, "AFTER")
#Set Soils Clip Layer symbology
#SymbologyLayer = ("Soils")
#lyr = ("SoilsClip")
#arcpy.ApplySymbologyFromLayer_management (lyr, SymbologyLayer)
arcpy.RefreshTOC()
#Update SoilsClip Layer
arcpy.mapping.UpdateLayer("Layers", "SoilsClip", "Soils", False)
arcpy.RefreshTOC()
mxd.save()
del mxd,
JeffMoulds
Instead of using strings for the input paramaters in UpdateLayer, use actual data frame and layer objects. For example:
arcpy.mapping.UpdateLayer(df, insertLayer, soilsLayer, False)
I noticed in your code, you already have a reference to a data frame and the SoilsClip layer - so you can use those, as I have above. However, you will also need to make a reference to the Soils layer, similar to how you referenced the SoilsClip layer.
Check out the syntax here for UpdateLayer: http://resources.arcgis.com/en/help/main/10.1/#/UpdateLayer/00s30000003p000000/. The paramater explanations have links to the Layer class help.
