ERROR 001272: Analyzer errors were encountered (codes = 7).
32875
48
07-03-2012 07:23 AM
AlanToms
Hello folks,
When trying to publish a map service am I get the followin error, ERROR 001272: Analyzer errors were encountered (codes = 7).  I have been able to track the issue to the definition query.  If a layer's defintion query has SHAPE.STLength() or SHAPE.STArea() in the query it will throw the error, but those are valid queries created using the Query Builder.  I have been unable to find details about ERROR 001272.  Any suggestions for a soltion?
Thakn you
Alan
JenniferRoberts
Any chance does your mxd or this layer have a spatial view, I am having a similar problem and am wondering if you cannot publish a spatial view to ArcSever.  My service which is getting this error is currently published in 10 and we are trying to now publish it in 10.1
BubbaHey
Occasional Contributor III
Try adding quotes   on the text field values in the definition query.
AlanToms
It is not a spatial view.
Adding quotes does not work as the quotes are incorrect syntax and this isnt a text value;  I tried it anyways and it threw a bad SQL message.
tms2000
Had the same error with a definition query on SHAPE.area > 15.  Removed the query and the service published fine.
AlanToms
Yes, but I need to have the definition query.  I'll think I'll put a ticket in with Esri Support.
JenniferRoberts
Hello folks,
Thakn you
Alan
We have the same problem (anyone trying to publish community mapping mxd's will!) I have heard from ESRI that the problem with a definition query on the shape.area/length that this is a bug. We are going to do some testing to see if we change the layer to a query layer if the same error will persist.  Will let you know how we make out but it is something you might want to try. 🙂
AledJones
Hi Alan,
Have ESRI support replied yet? I've taken one of our servers offline to perform the upgrade and now I can't carry on due to this issue.
Regards,
Aled
AlanToms
ESRI is aware of the problem.  Bug NIM082764: Analyzer error 00007: Layer's definition query is invalid is appearing when publishing unexpectedly when publishing enterprise data with a definition expression based on the geometry fields.
Alan
AledJones
Alan
Thanks for your reply. I couldn't find any reference to 'NIM082764' but I did find this one 'NIM083369' - I suppose the only possible solution is to duplicate the area fields?
Aled
