I have a Mapservice in WGS84 that I'd like to combine with ArcGIS Online services. I'm looking for code samples for the following 1. World_Street_Map services I can combine with my DynamicMap 2. Code to use 2 different projections
I put my basemap at the top of the list. That way, it will pick up on the projection of "my" data. Then, I just load the arcgisonline services as "dynamic", but below the WGS84 mapservice. Will slow it down a bit, but can project on the fly. Don't think it can on the fly tiles that were pre-made in mercator.
The tiles from TiledMapServiceLayer cannot be re-projected. Make the tiled map service as the first layer if you want to add other layers with a different spatial reference. If not, have all the layers in the same spatial reference.
Ok, I did get it to work this way as well. However ALL my services need to be loaded as dynamic for this to work. I find if you have many other layers on there, loading the arcgisonline as dynamic and re-projecting it on the fly is much faster than having to re-project all my data on the fly.
Plus, if I do it this way, all the coordinates listed are relative to the ESRI basemap projection, not your local data.
