DateFormatter for esriFieldTypeDate
4749
5
08-07-2012 10:38 AM
NaveenKatta
New Contributor III
Hi All,
I excuted spatial query and got the results, In that results one column is esriFieldTypeDate and that value is 1131321600000.
I try to convert it to MM/DD/YYYY using DateFormatter  but It is not working. Any idea??
Naveen
NaveenKatta
New Contributor III
I got the solution:
var sDate:Date = new Date(dateString);
var s2:String=DateField.dateToString(sDate,"MM/DD/YYYY ")
LanceGoens
New Contributor III
Can you show more of your code? I have a similar issue from an attribute query. The Graphic(s) contained in the returned FeatureSet contain attributes of esriFieldTypeDate but it's not displaying in any known date format. If your code above works, how are you detecting that the attribute is of the date format?
PierreLarondelle
New Contributor III
Here's the way I'm dealing the date format returned in esriFieldTypeDate type in an ItemRenderer :
data.datereservon = the value in esriFieldTypeDate from the FeatureLayer
dfData = Datefield in ItemRenderer.
It's certainly not the most elegant way of coding it  but it gives complete control on the final "look" of your date.
Hope it helps ...
protected function parseDateResOn():void
YourDateFormatterID.formatString = "DD/MM/YYYY";
var dateOn:Date = new Date(data.datereservon);
var dayFromDateStringed:String = dateOn.date.toString();
var monthFromDateStringed:String = dateOn.month.toString();
var yearFromDateStringed:String = dateOn.fullYear.toString();
var dateResOn:String = dayFromDateStringed + "/" + monthFromDateStringed + "/" + yearFromDateStringed;
dfData.text = dateResOn;
//data.datereservon = dateResOn;
RobertScheitlin__GISP
Pierre,
  Here is another way:
import spark.formatters.DateTimeFormatter;
var dateFormatter:DateTimeFormatter = new DateTimeFormatter();
dateFormatter.dateTimePattern = "DD/MM/YYYY";
dfData.text = dateFormatter.format(dateOn);
PierreLarondelle
New Contributor III
Short and efficient, thanks a lot Robert for sharing the best practices in Flex coding !
Pierre.
