Undo Not Functioning Correctly
Discussion created by joejorgie on Aug 8, 2012
Latest reply on Feb 6, 2013 by khodge-esristaff
I am having a problem with the undo command.  If I don't have ArcGIS for AutoCAD Build 300 loaded, the undo command functions properly.  However, if I have build 300 loaded - the undo command will only work to undo zoom commands.  Is there a setting that I need to change on the ArcGIS toolbar or within AutoCAD itself to make the undo command function properly?  Or is this a glitch?  I never had this problem with Build 250.  I am using AutoCAD Map 3D 2011.
