I am editing some shapes that I have digitized by changing locations of the vertices. When I make these edits it doesn't change my data in the attribute table. I am a student and working on an internship and would love to have some assistance!!!
These are polygons that are in a agricultural field and I am trying to get the polygons to be all the same area (.5 acre). How do I update the attribute table to reflect the shape in the map???
You can Calculate Geometry on the field by right-clicking the column head, selecting Calculate Geometry, and then configuring the units and coordinate system.
I have the same problem... I calculated area, perimeter etc. via the "calculate geometry" field and added other colums that use the values from area and perimeter. If I cut a polygon my table doesn´t refresh... I can easily update the calculated area but do I really need to type in the formulas for the other colums again since the data doesn´t seem to refresh? Reload cache doesn´t do anything either.
Hello Tim, thanks for your reply. I will give it a shot, the attribute assistant functions are still disabled in my programm but I hope I can figure this out.
