Dear All,
Can you help me to explain the difference between ArcGIS Server Staging and Deployment from the technical side?
I've read ArcGIS for server brochure, but not mention about the difference.
Thanks.
Wow, this thread is old, but since it was just commented on and given a bump, I'm adding my 2 cents.
Converting anibal martinez to English using google translate
Hello, I am doing the same consultation to the local representative in Argentina, and I have 3 days without response. Although 6 years have passed if this week I get to answer I commented.
Reading what I think you're referring to, is staging as the test, testing or Pre-production environment
Best regards
Anibal
I confirm that is what you comment staging is the test environment
My response to the the original post and above.
Although it is important to talk to your customer service rep or local distributor for cost and actual details, since things may vary between organization type and country, this is a rough recap of what we we are thinking about doing (State Agency in the US...no ELA).
Because we have our Adv Ent license for production, it sounds like for our staging license can be a "Standard Level" instead of an Advanced level. One of the main differences is we will get fewer Level 2 users for Portal, but since it is for staging/development and not deployment/production, for us that may work. But from what I understand (need to confirm) the actual software and functionalities (minus the Image Server for us) is the same, but your can not use for production.
All though not totally confirmed yet...what we lose going with a staging license vs the annual Developer Subscriptions (per person) is we will only be able to install on one machine (vs a Dev license can install and test on multiple...e.g. on their local machine), the Runtime development, and possibly the AGS Studio Development platform.
What we gain is not having to limit/control (licensing wise) the developers that have access to the staging machine.
I was planning on writing this up to share and discuss with our staff so I decided to share it here as as I get confirmation on some of the items (I'm going to have my rep see if I summarized our discussion correctly). I Hope this helps. Again,
Esri offers a staging license that can be used for either a development or a staging server. Each environment needs its own license. You could for instance have two staging licenses (one for the development and one for the staging servers) and for instance an advanced license for the production environment. Ideally, the environments use separate infrastructure and are as similar as possible, although that will be difficult since different scaling will most likely be applied to each environment.
Si, @Xander_Bakker así tenemos Desarrollo, Testing y Produccion, con sus licencias de ArcGis Server, ahora instalamos "ArcGis Portal" estamos esperando la respuesta del representante local, para que nos de los códigos de licencias de cada uno de estos 3 ambientes de "ArcGis Portal" y nos hablo de staging y surgió la duda sobre este tema.
Hola anibal martinez , me alegro que se haya aclarado las dudas. Espero que prontamente reciben los códigos de licencias para proceder con la instalación de los ambientes.
Mil gracias Rebecca Strauch, GISP, justamente es mi situación, nosotros tenemos definidos ambientes 3 (como las normas ISO IRAM recomiendan) , DESARROLLO, TESTING y PRODUCCION, por lo cual requerimos que todos los productos puedan licenciarse o instalarse compartiendo y apoyando tu vision sobre el tema "Because we have our Adv Ent license for production, it sounds like for our staging license can be a "Standard Level" instead of an Advanced level. One of the main differences is we will get fewer Level 2 users for Portal, but since it is for staging/development and not deployment/production, for us that may work. ". Si funcionaria!!!,
Gracias,
Anibal Martinez
Hola, estoy haciendo la misma consulta al representante local en Argentina, y llevo 3 días sin respuesta. Si bien han pasado 6 años si esta semana logro que me lo contesten te comento.
Leyendo lo que creo a que se refiere, es a Staging como al ambiente de prueba , Testing o Pre- Producción
Saludos,
Anibal
Te confirmo que es lo que te comente Staging es el ambiente de prueba
