I am having issues finding a suitable method of loading a rastered geotiff file into the accelerated layers collection. My current method that works fine is to load the image into a ElementLayer as follows.var image = new BitmapImage(new Uri(filePath));
var newLayer = new ElementLayer();
var rect = new Rectangle();
rect.SetValue(ESRI.ArcGIS.Client.ElementLayer.EnvelopeProperty, convertedEnvelope);
rect.Fill = new ImageBrush(image);
newLayer.Children.Add(rect);
_esriMap.Layers.Add(newLayer);
This method works fine except I have a accelerated layer collection that is rendering points from GPS readings that needs to be plotted on top of the rastered image. The only work around I can find is to change the opacity of the Element Layer in order to at least show the points behind the layer. This is a prefered method, I would like to be able to add the georeferenced image to a layer within my acceleratedLayers collection so I could set the layer order.If I have not explained my situation well enough let me know and I'll attempt to reword it.Regards, Aaron
