COP Template - Issue with ERG Tools
2288
11-07-2012 01:30 PM
MarkCollins
I'm trying to setup the ERG tools, which are part of the COP template for 10.1. When trying to execute either the ERG By Chamical or the ERG by Placard tools I get the following error. I am clicking on the map (in ArcMap 10.1) to place a point before running the tool. Can some please guide me down the right path? Here is the output from the tool:
Executing: ERGByChemical "Feature Set" "Ammonia, anhydrous" 0 Day Large C:\Users\Administrator.4QTRS\Documents\ArcGIS\Default.gdb\outerg
Start Time: Wed Nov 07 15:24:20 2012
Executing (ERG 2012 By Chemical Name): ERGByChemicalFunction "Feature Set" "Ammonia, anhydrous" 0 Day Large C:\Users\Administrator.4QTRS\Documents\ArcGIS\Default.gdb\outerg
   Get input source points
   Create output featureclass
    Input is in Decimal Degrees.  Trying to intersect with UTM zone and reproject.
   UTM ZONE: 7
   Add fields to store output values
The operation was attempted on an empty geometry.
Failed to execute (ERG 2012 By Chemical Name).
Failed at Wed Nov 07 15:24:21 2012 (Elapsed Time: 1.00 seconds)
Failed to execute (ERGByChemical).
Mark
MarkCollins
I have figured out what the issue was here. It was not working because I didn't have a basemap layer added to my map document when running the model.
MarkCollins
AbdelKhineche1
Hi Mark,
Maybe you can help:
My Material list is not showing and I have my basemap layers.
My "Lookup Wind Info" is not working either.
Thank you much,
Abdel
