how to associate the IDLE editor using ArcGIS v10.1
3132
11-23-2012 12:54 PM
karlkliparchuk
With ArcGIS v10, when I selected to edit a py script in ArcMap my IDLE editor would open.  Now in 10.1 when I select to edit my py script, I get NotePad.  Can someone advise me how to associate the IDLE editor with my py script in ArcMap?  Thanks.
UPDATE:
In the Geoprocessing Options window, you need to select the editor located on your computer.
MikeHunter
In Arcmap, go to Geoprocessing on the top menu bar, and then choose Geoprocessing options.  Down where it says Script Tool Editor/Debugger, in the slot that says Editor, put in the full path to idle.pyw.  On my machine, it is "C:\Python27\ArcGIS10.1\Lib\idlelib\idle.pyw"  It will probably be similar on yours.
good luck
Mike
