Hi!
What I am looking for is very basic. I have a project containing two modules. Now I want to call one module by the other module. What I mean is I want the second module to be executed by the first module. I thought the "call" command would be the right way to do but I always get an error message. I also tried writing in brackets ("Process1") but this didnt work as well. Any suggestion what command to use? Has this something to do with private and public subs?
Private Sub Testprocess()
Dim pMxDoc As IMxDocument
Dim pFeatLayer As IFeatureLayer
Dim pFeatureClass As IFeatureClass
Dim pFeatureCursor As IFeatureCursor
Dim pField As IField
Dim pFeature As IFeature
Set pMxDoc = ThisDocument
Set pFeatLayer = pMxDoc.FocusMap.Layer(0)
Set pFeatureClass = pFeatLayer.FeatureClass
Set pFeatureCursor = pFeatureClass.Search(Nothing, False)
Set pFeature = pFeatureCursor.NextFeature
Dim n As Integer
Dim pProcessID As Integer
Do Until pFeature Is Nothing
pProcessID = pFeature.Value(pFeature.Fields.FindField("Process_ID"))
If (pProcessID = 1) Then
Call Process1
Else: End If
Loop
End Sub
Thanks for your help
