File Geodatabase API 1.3 is now available for download.
9376
15
11-30-2012 06:03 AM
LanceShipman
The File Geodatabase API 1.3 is now available for download from the resource center. (http://www.esri.com/apps/products/download/)
What�??s new at 1.3:
  • Added support for MS Visual Studio 2012.
  • Fix the MutlipatchShapebuffer helper functions and correct multipatch documentation errors in the extended_shape_buffer_format.pdf.(NIM078028)
  • QueryEnvelope does not correctly calculate M and Z extent. (NIM082237)
  • Supported GCS (Geographic Coordinate System) and PCS (Projected Coordinate System) updated to match 10.1 sp1.
Fixed Issues:
NIM078028 Fix the MutlipatchShapebuffer helper functions.
NIM082237 QueryEnvelope does not correctly calculate M and Z extent.
NIM084105 MultiPartShapeBuffer::GetMs return the wrong pointer value
NIM085366 Using only a null or empty geometry results in a invalid extent.
__11
It would probably be helpful to update http://resources.arcgis.com/content/geodatabases/10.0/file-gdb-download, which still has v1.2
HalWatson
New Contributor III
1.  Does the v 1.3 API support access to FGDBs created with ArcGIS 10.2 ?
2.  Does the v 1.3 API support access to compressed FGDBs or compressed featureclasses within a FGDB ?
Thanks,  HW
LanceShipman
File Geodatabase API supports all versions of 10.x.
v 1.3 does not support reading or writing compressed data. Reading compressed data will be supported at v 1.4.
We have been buried under the 10.3 ArcGIS release and the Pro 1.0 release so haven't had a chance to finish up 1.4. We hope to have an estimate of the release date soon.
HalWatson
New Contributor III
Thanks for the reply, that helps.  Looking forward to the 1.4 release. Good luck!
PaulAustin
Any chance the following will be fixed or available in the 1.4 release.
  • Thread support. Right now things crash if you create different file geodatabases in multiple threads. I'm not looking for full threading support for a single file geodatabase. But it would be nice to operate on different file geodatabases without having the synchronize on the whole API. I think the main issue is the XML library having shared data so you can't even use it in multiple threads.
  • Support for order by on date and integer columns.
  • Not crash on windows when creating a FGDB after deleting another FGDB.
  • Not completely crash if invalid SQL is issued
  • More meaningful errors (e.g. file XXX not found) rather than general function errors if files go missing (e.g. network failure)
  • A gcc compatible library on windows as well as Visual Studio
LanceShipman
  • Thread support will not be changing at 1.4. We are aware of the XML library issue, but it we will not be replacing it at the 1.4 release.
  • ORDER BY on DATE and INTEGER columns is supported. Be aware that the ordering field must be included in the field list. This is true in ArcObjects and in the API.
  • We do not see a crash in windows when creating a FGDB after deleting another FGDB. Please supply example code.
  • We don't see a crash when invalid SQL is used. Please supply example code.
  • We will not be including gcc on windows at 1.4. We already support VS2010, VS2012, and VS2013. Linux 32-bit, Linux 64-bit, Both gcc and Clang on MacOS.
UlrichEgger
New Contributor III
I have already asked twice about File Geodatabase API 1.4.
So:
  • When do you plan to publish this release?
  • What do you mean in “We already support (…) VS2013”?
PaulAustin
1.4 seems to have solved the crash I has with sorting data and string columns
LanceShipman
  • We plan on releasing the 1.4 version of the API in March 2015
  • VS 2013 support is in 1.4
