Remove Copyright Text
3459
12-10-2012 01:41 PM
ShaunWeston
How do you remove the copyright text from appearing in the bottom right hand corner of Javascript API application. I've looked around a bit, but can't seem to figure out how. It is easy enough to remove the Esri logo, but the copyright test from map services, I can't see how to disable?
ReneRubalcava
Try adding showAttribution: false to the constructor parameters.
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jsapi/map.htm#MapConst
var map = new esri.Map('mapdiv', { showAttribution: false });
ReneRubalcava
ShaunWeston
Ah! sweet, too easy...thanks!
sunithanaik
Thanks a lot for the answer, it works.
JackFairfield
Occasional Contributor II
If you come across this post and are looking for an answer in Esri Javascript 4.0, try this:
view.ui.remove("attribution");
This will remove the widget from the ui of the view.  In 4.0, the attibution widget is added by default.
Alternatively, you can specify the widgets you want created automatically in the default UI object when defining your view
See DefaultUI | API Reference | ArcGIS API for JavaScript 4.0
Fore more details.
