Solved! Go to Solution.
import arcpy try: #Specifies mxd mxd = arcpy.mapping.MapDocument(r"H:/Desktop/Masterarbeit/test/Besprechung_Crap Ses.mxd") #Specifies dataframe of interest df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] #Specifies layer file with the symbology you want to apply to the other raster layers sourceLayer = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files\Reach Probability.lyr") #Loops through layers in the first data frame in your mxd and #creates a list of Layers starting with Reach_probability: for lyr in arcpy.mapping.ListLayers(mxd, "Reach_probability*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer) #Saves mxd mxd.save() finally: #Deletes the reference to the mxd from memory (not the actual mxd file) del mxd
# --------------------------------------------------------------------------- # iteration durch raster_und symbol.py # Created on: 2012-12-31 01:39:43.00000 # (generated by ArcGIS/ModelBuilder) # Description: # --------------------------------------------------------------------------- import arcpy #Specifies mxd mxd = arcpy.mapping.MapDocument(r"H:/Desktop/Masterarbeit/test/Besprechung_Crap Ses.mxd") #Specifies dataframe of interest df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] #Specifies layer file with the symbology you want to apply to the other raster layers sourceLayer1 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_95CI.lyr") sourceLayer2 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_95CI_diff.lyr") sourceLayer3 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_mean.lyr") sourceLayer4 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_mean_diff.lyr") sourceLayer5 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_depos_diff.lyr") sourceLayer6 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_deposited.lyr") sourceLayer7 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_pass_diff.lyr") sourceLayer8 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_passages.lyr") sourceLayer9 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_tree_impacts.lyr") sourceLayer10 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_95CI.lyr") sourceLayer11 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_95CI_diff.lyr") sourceLayer12 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_mean.lyr") sourceLayer13 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_mean_diff.lyr") sourceLayer14 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Reach Probability [%].lyr") sourceLayer15 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Reach_prob_diff.lyr") sourceLayer16 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Rvol.lyr") sourceLayer17 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Rvol_diff.lyr") sourceLayer18 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Tree_impact_heights.lyr") sourceLayer19 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Vmax.lyr") sourceLayer20 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Vmax_diff.lyr") #Loops through layers in the first data frame in your mxd and #creates a list of Layers starting with Reach_probability: for lyr in arcpy.mapping.ListLayers(mxd, "E_95CI", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer1) print "done_ 1" for lyr in arcpy.mapping.ListLayers(mxd, "E_95CI_diff*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer2) #Saves mxd mxd.save() print "done_2" for lyr in arcpy.mapping.ListLayers(mxd, "E_mean", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer3) print "done_3" for lyr in arcpy.mapping.ListLayers(mxd, "E_mean_diff*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer4) #Saves mxd mxd.save() print "done_4" for lyr in arcpy.mapping.ListLayers(mxd, "Nr_depos_diff*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer5) print "done_5" for lyr in arcpy.mapping.ListLayers(mxd, "Nr_deposited", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer6) #Saves mxd mxd.save() print "done_6" for lyr in arcpy.mapping.ListLayers(mxd, "Nr_pass_diff*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer7) print "done_7" for lyr in arcpy.mapping.ListLayers(mxd, "Nr_passages", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer8) #Saves mxd mxd.save() print "done_8" for lyr in arcpy.mapping.ListLayers(mxd, "Nr_tree_impacts*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer9) print "done_9" for lyr in arcpy.mapping.ListLayers(mxd, "Ph_95CI", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer10) #Saves mxd mxd.save() print "done_10" for lyr in arcpy.mapping.ListLayers(mxd, "Ph_95CI_diff*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer11) print "done_11" for lyr in arcpy.mapping.ListLayers(mxd, "Ph_mean", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer12) #Saves mxd mxd.save() print "done_12" for lyr in arcpy.mapping.ListLayers(mxd, "Ph_mean_diff*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer13) print "done_13" for lyr in arcpy.mapping.ListLayers(mxd, "Reach Probability [%]*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer14) #Saves mxd mxd.save() print "done_14" for lyr in arcpy.mapping.ListLayers(mxd, "Reach_prob_diff*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer15) print "done_15" for lyr in arcpy.mapping.ListLayers(mxd, "Rvol", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer16) #Saves mxd mxd.save() print "done_15" for lyr in arcpy.mapping.ListLayers(mxd, "Rvol_diff*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer17) print "done_17" for lyr in arcpy.mapping.ListLayers(mxd, "Tree_impact_heights *", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer18) #Saves mxd mxd.save() print "done_18" for lyr in arcpy.mapping.ListLayers(mxd, "Vmax", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer19) print "done_19" for lyr in arcpy.mapping.ListLayers(mxd, "Vmax_diff*", df): #Determines if layer is a raster layer and applies lyr symbology if it is if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer20) #Saves mxd mxd.save() print "done_ 20! :D ! " #Deletes the reference to the mxd from memory (not the actual mxd file) del mxd
