The ArcGIS Runtime SDK 10.1.1 for WPF is now available!
7151
23
01-22-2013 06:24 AM
MichaelBranscomb
Esri Frequent Contributor
We're very pleased to announce that the ArcGIS Runtime SDK 10.1.1 for WPF is now available for download from the Customer Care Portal: http://customers.esri.com/.
Make sure you take a look at the Release Notes for a list of enhancements, changes and known limitations in this release:
http://resources.arcgis.com/en/help/runtime-wpf/concepts/index.html#/Release_notes_ArcGIS_Runtime_SD...
... And here are some other resources you may find useful:
Blog Announcement: http://blogs.esri.com/esri/arcgis/2013/01/17/arcgis-runtime-sdk-for-wpf-10-1-1-is-here/
Resource Center: http://resources.arcgis.com/en/communities/runtime-wpf/index.html
Conceptual Doc: http://resources.arcgis.com/en/help/runtime-wpf/concepts/index.html#//017000000031000000
*New* Samples: http://resources.arcgis.com/en/help/runtime-wpf/samples/index.html
API Reference Library: http://resources.arcgis.com/en/help/runtime-wpf/apiref/index.html
Sample App download (if you don't have the SDK): http://www.arcgis.com/home/item.html?id=ace12032e3db4314b7ba7ee5b341c80c
Cheers
Mike
TangYang
Cheers
Mike
Hi,Mike!
Could you please tell the address where I can download the latest version of ArcGIS SDK for WPF? I have been looking for it for so long,but haven't got one.
DominiqueBroux
The current WPF SDK is now the version 10.2.3. It can be downloaded from here.
If you start a new project you should also consider using the new .Net API.
MichaelBranscomb
You need to go to http://customers.esri.com/ and log in with an ESRI global ID that has an EDN subscription associated with it and you'll be able to download all the EDN software, including the ArcGIS Runtime SDK for WPF.
Cheers
Mike
TangYang
Got it !
Thanks a lot!
tanqintan
[ATTACH=CONFIG]22624[/ATTACH]
please tell me what is wrong? thanks!
MichaelBranscomb
Please can you provide some more information?
Or alternatively - please contact you local distributor.
Mike
BKuiper
Occasional Contributor III
Just upgraded. Works great. Also discovered AppDataPath property. That is useful!
ae
The functionality in the new API looks great, and as a user of the earlier version ArcGIS API for WPF 2.4 I would really like to upgrade to use this library instead. However, while the earlier version was freely available, it seems like I need an EDN subscription in order to get hold of the new API. Could you clarify for me whether it is possible to get hold of the API without an EDN subscription? I do not need all the other stuff that comes with and EDN subscription, and cannot really afford the yearly cost of having this subscription.
Cheers
AnkitaBhatia
New Contributor III
Could someone please tell how is ArcGIS Runtime SDK for WPF different from ArcGIS API for WPF?
Also, how can I make sure the Application I am building uses ArcGIS Runtime SDK for WPF and not the ArcGIS API for WPF?
Kindly reply ASAP.
