// dojo's layout dijits and the parser to auto-create the dijits require(["dijit/layout/BorderContainer", "dijit/layout/ContentPane"]); // bring in dgrid, esri and dojo modules // create the grid and the map // then parse the dijit layout dijits /// <reference path="jsapi_vsdoc10_v33.js" /> require(["dgrid/OnDemandGrid", "dgrid/Selection", "dojo/store/Memory", "esri/map", "esri/layers/FeatureLayer", "dojo/_base/declare", "dojo/number", "dojo/parser", "dojo/domReady!"], function (Grid, Selection, Memory, Map, FeatureLayer, declare, dojoNum, parser) { // call the parser to create the dijit layout dijits parser.parse(); // create the dgrid window.grid = new (declare([Grid, Selection]))({ // use Infinity so that all data is available in the grid bufferRows: Infinity, columns: { "OBJECTID": "ID", "SAN_ERFOR": "Sanierung erforderlich", "GEFAHR": "Gefahr", "STATUS": "Status" } }, "grid"); // add a click listener on the ID column grid.on(".field-id:click", selectState); window.map = new esri.Map("map", { basemap: "gray", center: [-101.426, 42.972], zoom: 4 }); window.statesUrl = "http://defg1gis01/ArcGIS/rest/services/hws/MapServer/1"; window.outFields = ["OBJECTID", "SAN_ERFOR", "GEFAHR", "STATUS"]; var fl = new FeatureLayer(window.statesUrl, { id: "states", mode: 1, // ONDEMAND, could also use esri.layers.FeatureLayer.MODE_ONDEMAND outFields: window.outFields }); dojo.connect(fl, "onLoad", function (fl) { fl.maxScale = 0; fl.setSelectionSymbol(new esri.symbol.SimpleFillSymbol().setOutline(null).setColor("#AEC7E3")); }); dojo.connect(fl, "onClick", selectGrid); map.addLayer(fl); dojo.connect(map, "onLoad", function (map) { // show the border container now that the dijits // are rendered and the map has loaded dojo.style(dijit.byId("container").domNode, "visibility", "visible"); populateGrid(Memory); // pass a reference to the MemoryStore constructor }); } ); function populateGrid(Memory) { var qt = new esri.tasks.QueryTask(window.statesUrl); var query = new esri.tasks.Query(); query.where = "1=1"; query.returnGeometry = true; query.outFields = window.outFields; qt.execute(query, function (results) { var data = dojo.map(results.features, function (feature) { return { // property names used here match those used when creating the dgrid "OBJECTID": feature.attributes[window.outFields[0]], "SAN_ERFOR": feature.attributes[window.outFields[1]], "GEFAHR": feature.attributes[window.outFields[2]], "STATUS": feature.attributes[window.outFields[3]] } }); var memStore = new Memory({ data: data }); window.grid.set("store", memStore); }); } // fires when a row in the dgrid is clicked function selectState(e) { // select the feature var fl = map.getLayer("states"); var query = new esri.tasks.Query(); query.objectIds = [parseInt(e.target.innerHTML)]; fl.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (result) { if (result.length) { // re-center the map to the selected feature window.map.centerAt(result[0].geometry.getExtent().getCenter()); } else { console.log("Feature Layer query returned no features... ", result); } }); } // fires when a feature on the map is clicked function selectGrid(e) { var id = e.graphic.attributes.OBJECTID; // select the feature that was clicked var query = new esri.tasks.Query(); query.objectIds = [id]; var states = map.getLayer("states"); states.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW); // select the corresponding row in the grid // and make sure it is in view grid.clearSelection(); grid.select(id); grid.row(id).element.scrollIntoView(); }
I resolved "4)Only 125 rows do get loaded/display." by the following code.
You Memory is missing id field. that is the reason the grid not displaying more than 125 records.
In your case set OBJETCID is id field for Memory.
// var memStore = new Memory({ data: data });
var memStore = new Memory({ data: data,idProperty: "OBJECTID"});
