import ascii to raster
4604
6
01-28-2013 08:38 PM
LinaMENG
I am trying to import a ascii data to raster via the toll "ascii to raster", but a error is reported (ERROR 010067: Error in executing grid expression) during the conversion process. I open the ascii file by notepad, it seems that the header information is miss, but the data author claims that the file format is exactly correct. So I am wondering what is reason producing such error?
TarunJaiswal
Greetings!
Please take a look at the following forum post.
http://forums.arcgis.com/threads/48973-Cant-get-.asc-files-to-display-as-dtm?p=168120#post168120
Hope this will help.
Thanks!
ElizabethPerotti
Every time I click on this link, it sends me somewhere that isn't a thread. This was the link I originally tried to use and is why I put up this question.
GayathriAlallasundaram
New Contributor III
Please try to convert your ASCII file to some other raster output format other than grid, may be an IMG or TIFF or a file geodatabase raster.
Gayathri A.
LinaMENG
Greetings!
Thanks!
Thanks for your reply! I still could not open the ascii file via the arcgis conversion tool. do I need to modify the ascii file by adding the header information to the file? here is de demo of ascii file at the begining of the file:
0.000000E+00
0.000000E+00
0.000000E+00
0.000000E+00
0.000000E+00
the author of the data claims that it is exactly the  right file structure " The *.asc you sent is the file structure.  Get someone to help you on how to import ASCII into Arcgis.  There are 360*180 (=64,800) lines in the file."
So, how can I import that file to arcgis with the limited header information?
Many thanks!
LinaMENG
Gayathri A.
Yes, I tried, but it failed with the same error message:
010067 : Error in executing grid expression.
I think there are some problem with the fiel structure of ascii file, not the exporting file.
Thanks!
LinaMENG
Greetings!
Thanks!
I check the data again and it seems that it is written by FORTRAN! how could i import such file to arcgis?!
