Solved! Go to Solution.
There is another thread here which marks this code as the final answer but in the latest api 10.1, this just results in a blank image which is quite confusing for me.
I would appreciate if some one can help me deal with this.
thanks and Regards
H Akhtar
CAEAGLLayer *eaglLayer = (CAEAGLLayer *) theMap.layer; eaglLayer.drawableProperties = @{ kEAGLDrawablePropertyRetainedBacking: [NSNumber numberWithBool:YES], kEAGLDrawablePropertyColorFormat: kEAGLColorFormatRGBA8 };
- (NSData *)getImage{ //the rest GLint width; GLint height; glGetRenderbufferParameteriv(GL_RENDERBUFFER, GL_RENDERBUFFER_WIDTH, &width); glGetRenderbufferParameteriv(GL_RENDERBUFFER, GL_RENDERBUFFER_HEIGHT, &height); NSInteger myDataLength = width * height * 4; // allocate array and read pixels into it. GLubyte *buffer = (GLubyte *) malloc(myDataLength); glReadPixels(0, 0, width, height, GL_RGBA, GL_UNSIGNED_BYTE, buffer); // gl renders "upside down" so swap top to bottom into new array. // there's gotta be a better way, but this works. GLubyte *buffer2 = (GLubyte *) malloc(myDataLength); for(int y = 0; y < height; y++) { for(int x = 0; x < width * 4; x++) { buffer2[((height - 1) - y) * width * 4 + x] = buffer[y * 4 * width + x]; } } // make data provider with data. CGDataProviderRef provider = CGDataProviderCreateWithData(NULL, buffer2, myDataLength, NULL); // prep the ingredients int bitsPerComponent = 8; int bitsPerPixel = 32; int bytesPerRow = 4 * width; CGColorSpaceRef colorSpaceRef = CGColorSpaceCreateDeviceRGB(); CGBitmapInfo bitmapInfo = kCGBitmapByteOrderDefault; CGColorRenderingIntent renderingIntent = kCGRenderingIntentDefault; // make the cgimage CGImageRef imageRef = CGImageCreate(width, height, bitsPerComponent, bitsPerPixel, bytesPerRow, colorSpaceRef, bitmapInfo, provider, NULL, NO, renderingIntent); //CGImageRef imageRefCopy = CGImageCreateCopy(imageRef); // then make the uiimage from that UIImage *myImage = [[UIImage alloc] initWithCGImage:imageRef]; NSData *iDat = UIImageJPEGRepresentation(myImage, .5); CGImageRelease(imageRef); CGDataProviderRelease(provider); CGColorSpaceRelease(colorSpaceRef); free(buffer); free(buffer2); return iDat; }
thanks and Regards
H Akhtar
Thanks a lot for this... However this only works in the simulator but the same code returns a blank screen in the device.
Any idea why this might be.\
Thanks again
Thanks again
Hey Guys,
I have followed the above example and tried moving the renderers around. Like some of the other comments the code works great in the simulator but when I put it onto my iPad, I get a black image. Has anyone figured this out? I am sure I am just doing something wrong.
Cheers,
Jeff
-(void) PrintPermitFinal { CAEAGLLayer *eaglLayer = (CAEAGLLayer *) self.mapView.layer; eaglLayer.drawableProperties = @{ kEAGLDrawablePropertyRetainedBacking: [NSNumber numberWithBool:YES], kEAGLDrawablePropertyColorFormat: kEAGLColorFormatRGBA8 }; // reset buttons [selfsettoInitialMapView]; // create image and pdf UIImage *screenshot = [[UIImage alloc] initWithData:[self getImage]]; // use clip path Rect to clip image to right size CGImageRef imageref = CGImageCreateWithImageInRect([screenshot CGImage], clipRect); screenshot = [UIImage imageWithCGImage:imageref]; //save image to photo album for testing only UIImageWriteToSavedPhotosAlbum(screenshot,self,@selector(image:didFinishSavingWithError:contextInfo:),nil); //Send Image to Dictionary if (AppDelagate.PermitImages == nil) { AppDelagate.PermitImages = [[NSMutableDictionaryalloc] init]; } NSString *Key= [selfCreatePermitID:[AppDelagate.GraphicToPrint.allAttributesvalueForKey:@"Full_Name"] AndAddress:[AppDelagate.GraphicToPrint.allAttributesvalueForKey:@"Owner_Address"]]; [AppDelagate.PermitImages setObject:screenshot forKey:Key]; self.tabBarController.selectedViewController = [self.tabBarController.viewControllersobjectAtIndex:1]; }
- (NSData *)getImage { GLint width; GLint height; glGetRenderbufferParameteriv(GL_RENDERBUFFER, GL_RENDERBUFFER_WIDTH, &width); glGetRenderbufferParameteriv(GL_RENDERBUFFER, GL_RENDERBUFFER_HEIGHT, &height); NSInteger myDataLength = width * height * 4; // allocate array and read pixels into it. GLubyte *buffer = (GLubyte *) malloc(myDataLength); glReadPixels(0, 0, width, height, GL_RGBA, GL_UNSIGNED_BYTE, buffer); // gl renders "upside down" so swap top to bottom into new array. // there's gotta be a better way, but this works. GLubyte *buffer2 = (GLubyte *) malloc(myDataLength); for(int y = 0; y < height; y++) { for(int x = 0; x < width * 4; x++) { buffer2[((height - 1) - y) * width * 4 + x] = buffer[y * 4 * width + x]; } } // make data provider with data. CGDataProviderRef provider = CGDataProviderCreateWithData(NULL, buffer2, myDataLength, NULL); // prep the ingredients int bitsPerComponent = 8; int bitsPerPixel = 32; int bytesPerRow = 4 * width; CGColorSpaceRef colorSpaceRef = CGColorSpaceCreateDeviceRGB(); CGBitmapInfo bitmapInfo = kCGBitmapByteOrderDefault; CGColorRenderingIntent renderingIntent = kCGRenderingIntentDefault; // make the cgimage CGImageRef imageRef = CGImageCreate(width, height, bitsPerComponent, bitsPerPixel, bytesPerRow, colorSpaceRef, bitmapInfo, provider, NULL, NO, renderingIntent); // then make the uiimage from that UIImage *myImage = [[UIImage alloc] initWithCGImage:imageRef]; NSData *iDat = UIImageJPEGRepresentation(myImage, 0); CGImageRelease(imageRef); CGDataProviderRelease(provider); CGColorSpaceRelease(colorSpaceRef); free(buffer); free(buffer2); return iDat; }
