converting latitude and longitude from meter to decimal format
400
02-24-2013 08:43 AM
johnfred
HI,
I have a large no of data i.e. latitude and longitude in meters format,(995866.8412), i want to convert them into decimal format(25.55941), is there any method which can do this conversion in bulk.
VinceAngelo
Esri Esteemed Contributor
Unfortunately, this isn't really a trivial thing.  Data in meters must be in a projection.  You need
to know what the projection is, so you can de-project it into decimal degrees.  The conversion
itself is simple, but without knowing the source projection (and the target datum for the degrees,
if it's different from the datum used in the projection), there's literally no way to get there.
When you have the projection, you'll also need to tell us what GIS software you have available to
do the conversion.
- V
johnfred
Projection name is Ain el Abd / UTM zone 38N, and currently we are not using any GIS software , we are receiving it the data in an excel sheet and then upload that excel sheet into a DB table , so while inserting in in the DB table we want to convert that data to decimal format.
johnfred
correction to my last post:
Base Geographic CRS: Ain el Abd
Projection: UTM zone 38N
Code: 16038
VinceAngelo
I'm not aware of any way to execute deprojection without GIS software.
- V
