UniqueValueRenderer with array of values
4376
02-26-2013 01:30 AM
MarcoBrugna
Hi everyone,
is it possibile to create a UniqueValueRenderer using an array of values?
Something like this:
var info = {
                value: [1778,1779],
                symbol: new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([256,0,0]))
var renderer = new esri.renderer.UniqueValueRenderer(defaultSymbol, "O");
renderer.infos = [info];
I have a layer with about 3000 polygons and I need to add tree type of symbols (red, yellow and green) based on a value coming from a database.
PS. With ArcGis Dekstop this thing is possibile using the groups in the Unique Value Symbology.
Thanks in advance
Marco
MartinOver
New Contributor III
Using an array instead a single string would be perfect for many solutions.
Please consider an implementation.
Best,
Martin
ChristopherTotty
New Contributor III
You can accomplish this functionality using multiple calls to your renderer's addValue method in combination with passing a function into the UniqueValueRenderer constructor.  Check out this example:
r.addValue(3, greenSymbol);
renderer = new UniqueValueRenderer(defaultSymbol, function (value) {
  var expectedRedValue = 'red'; //You provide these based on your data
  var expectedYellowValue = 'yellow';
  var expectedGreenValue = 'green';
  if (value.attributes.YourAttribute == expectedRedValue) {
       return 1;
  else if (value.attributes.YourAttribute == expectedYellowValue) {
       return 2;
  else if (value.attributes.YourAttribute == expectedGreenValue) {
       return 3;
renderer.addValue(1, redSymbol);
renderer.addValue(2, yellowSymbol);
renderer.addValue(3, greenSymbol);
MartinOver
New Contributor III
Thanks for this solution.
We would like to use the UniqueValueRenderer inside the dynamicLayers parameter with a direkt browser request. The Request gets very long when the whole uniqueValueInfos part must be repeated for every single value.
Best,
Martin
