Arcpy Export report error
5216
8
04-16-2013 06:55 AM
DavidMeek
Hello all,
I'm working on trying to use arcpy to automate the creation of a report, but I'm running into a problem.
>>> arcpy.mapping.ExportReport('2013pp',"C:\reports\2013_Graffiti.rlf","C:\reports\2013_Graffiti_report.pdf")
    Runtime error
      File "<string>", line 1, in <module>
      File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\utils.py", line 181, in fn_
        return fn(*args, **kw)
      File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\mapping.py", line 506, in ExportReport
        assert isinstance(report_source, (MapDocument, TableView, Layer)), str(type(report_source))
    AssertionError: <type 'str'>
I'm having trouble deciphering the traceback as it seems to reference a variety of internal python files. In trouble shooting so far, I thought the problem might be that the report_source needs to be a layer file and I was using a .shp so I converted to a .lyr but then I get the error:
    Parsing error SyntaxError: invalid syntax (line 1)
Any advice would be greatly appreciated,
Best,
David
ToddLusk
New Contributor III
It's a problem with the file path strings.  Python is picky about the "slashes".  You have to either switch your "\" to "\\" or "/" or throw an "r" in front of the existing strings as you have them now.
"C:\\reports\\2013_Graffiti.rlf","C:\\reports\\2013_Graffiti_report.pdf"
OR
"C:/reports/2013_Graffiti.rlf","C:/reports/2013_Graffiti_report.pdf"
OR
r"C:\reports\2013_Graffiti.rlf",r"C:\reports\2013_Graffiti_report.pdf"
JasonScheirer
Occasional Contributor III
The first argument to exportreport must be an arcpy.mapping object. For example:
mxd = arcpy.mapping.MapDocument('current')
df = arcpy.mapping.ListDataFrames(mxd, 'Layers')[0]
layer = arcpy.mapping.ListLayers(df, '2013pp')[0]
arcpy.mapping.ExportReport(layer,"C:\reports\2013_Graffiti.rlf","C:\reports\2013_Graffiti_report.pdf")
deleted-user-mezzanRtr2IZ
New Contributor III
I am experiencing problems with arcpy.mapping.Exportreport as well since my desktop was updated to 10.2.1 earlier this week. I am attempting to export a .pdf report but encounter the follwing error:
File "C:\Users\Jeff\Documents\WORK\RECOVER\GetFireReportsData.py", line 69, in <module>
arcpy.mapping.ExportReport(lyr, rlf, (r"C:/Data/RECOVER2/" + fireName + "Fire_detailed.pdf"))
File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\utils.py", line 181, in fn_
File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\mapping.py", line 515, in ExportReport
return report_source._arc_object.ExportReport(*gp_fixargs((report_layout_file, output_file, dataset_option, report_title, starting_page_number, page_range, report_definition_query, extent, field_map), True))
RuntimeError: Error in generating report
This is the function, pretty simple. It was working fine and the .pdf report was successfully generating last week when I was running 10.2.0. Can anybody tell me what is going on (mind that this is just part of a larger program, obviously I have imported arcpy.)?
lyr = arcpy.mapping.Layer("<path>")
rlf = ("<path>")
arcpy.mapping.ExportReport(lyr, rlf, "<path>_detailedReport.pdf")
Apologies for remaining vague. I must repeat, this was working prior to the 10.2.1 update.
MichaelMattaini1
Did you ever find a solution to this problem? I'm using 10.3 but getting the same thing:
Runtime error
  File "N:/13057/13057.3/Production/InspectionOnCall/Testing/PDF Generation Testing.py", line 14, in <module>
    generateReports("VPS-030")
  File "N:/13057/13057.3/Production/InspectionOnCall/Testing/PDF Generation Testing.py", line 12, in generateReports
    arcpy.mapping.ExportReport(inTable, template, "workOrder" + str(workOrderID) + ".pdf", "DEFINITION_QUERY", "Baltimore County DPW Bureau of Utilies On-call Contract Management", report_definition_query="SELECT * FROM tbl_Asset_Tracking WHERE WorkOrder = " + str(workOrderID))
  File "c:\program files\arcgis\desktop10.3\arcpy\arcpy\utils.py", line 182, in fn_
  File "c:\program files\arcgis\desktop10.3\arcpy\arcpy\mapping.py", line 532, in ExportReport
New Contributor III
Apologies upfront.  Being over a year ago, I can't recall exactly what was done to resolve this.  I did learn that ExportReport will not support background processing and it did not seems to like being a part of a stand alone Python script either.  I was able to execute this funtion by turning off background processing and running the script via a ArcMap Script Tool.
PatrickSeastar
New Contributor III
Thanks, this did the trick for me as well. Not sure though why this function works better within an ArcMap environment rather then running as a standalone script.
Thanks for the help.
curtvprice
MVP Esteemed Contributor
arcpy.mapping.ExportReport(inTable, ...
Is <path> a table or feature class? If so this won't work, you need to create a layer object.
New Contributor III
report_src in arcpy.ExportReport() can be reference to layer file or a table view. I am utilizing the former in this example.
