ahigh2
LineSymbol and SimpleLineSymbol not rendering without AcceleratedDisplay
Discussion created by ahigh2 on Apr 19, 2013
Latest reply on Jun 27, 2013 by MBranscomb-esristaff
I'm working through some performance issues with the accelerated display and have switched to working without it enabled. With the AcceleratedDisplay enabled, SimpleLineSymbols and LineSymbols both render correctly. If I turn it off, both fail to render completely. Nothing else has changed such as their geometries or symbologies. Is this a known issue and/or am I doing something wrong? Additionally, SimpleFillSymbols, PictureMarkerSymbols, and TextSymbols seem to work just fine regardless of AcceleratedDisplay settings.
Thanks.
EDIT: Code sample below
private void MakeSimpleSymbol()
            //Create a simple line symbol
            SimpleLineSymbol sls = new SimpleLineSymbol();
            sls.Color = new SolidColorBrush(Colors.Blue);
            sls.Style = SimpleLineSymbol.LineStyle.Solid;
            sls.Width = 2;
            //Create a polygon object
            Polygon p = new Polygon();
            p.SpatialReference = new SpatialReference(102100);
            //Populate it with some points
            ESRI.ArcGIS.Client.Geometry.PointCollection pointCollection = new ESRI.ArcGIS.Client.Geometry.PointCollection();
            ObservableCollection<ESRI.ArcGIS.Client.Geometry.PointCollection> rings = new ObservableCollection<ESRI.ArcGIS.Client.Geometry.PointCollection>();
            MapPoint wgsPoint = new MapPoint(0,0);
            MapPoint wgsPoint2 = new MapPoint(50,0);
            MapPoint wgsPoint3 = new MapPoint(0,50);
            pointCollection.Add(wgsPoint);
            pointCollection.Add(wgsPoint2);
            pointCollection.Add(wgsPoint3);
            rings.Add(pointCollection);
            p.Rings = rings;
            //Create a graphic and set its properties
            Graphic graphic = new Graphic();
            graphic.Geometry = p;
            graphic.Symbol = sls;
            //Create a graphics layer and add the graphic to it
            GraphicsLayer gLayer = new GraphicsLayer();
            gLayer.Graphics.Add(graphic);
            //Add the graphics layer to the map
            _map.Layers.Add(gLayer);
And in the XAML:
<Window x:Class="ESRIWPFTestApplication.MainWindow"
     xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
        Title="MainWindow" Height="350" Width="525">
    <Grid>
        <!-- AcceleratedDisplay is OFF -->
        <esri:Map x:Name="_map" UseAcceleratedDisplay="False">
        </esri:Map>
    </Grid>
</Window>
Outcomes
