Error [000000_12301899] when performing "Zonal Statistics as Table"
4139
04-22-2013 05:28 AM
VincentMuller
Hi there,
I've been trying to run a Zonal Statistic as Table on a raster file but it never works. It does 0% of the operation and the table is empty.
I get the following error message: "Zonal Statistics as Table [000000_12301899]"
When I try with another raster file, the same calculation works with no problem so I came to think that it is a file related issue.
There is not a big difference except that the file I need to work on has the following info:
Columns and rows: 1500, 1000
Number of bands: 1
Cellsize: 0,6, 0,6
Pixel type: unsigned integer
The other file that worked had much bigger cells. I'm not sure if cellsize is the problem here.
I tried to disable the Background Geoprocessing but it didn't help. When it is disable the whole software crashes.
I'm getting really upset wasting my time with something that should take 2 minutes and ends up taking the whole day.
Any help would be very welcome.
For information I have ArcGIS 10 Service Pack 4.
Thanks you in advance!
Regards, Vincent
SchuylerBorges
Hey Vincent!
I am in the same situation with the viewshed tool (same exact stuff is happening to me). Did you ever figure this out or learn about how to fix it?
