Hi.. I'm a first time user of the ArcGIS API for javascript.Problem:My custom BasemapGallery widget, an slightly altered version of the BasemapGallery widget example in the documentation website link does not change the basemap of my main map like the example.What did I do wrong. What am I missing. Help.Description:Using API 3.4 but using dojo 1.6 non-AMD style coding.I wanted to modularize my webmap to be as much as possible so separated the html and javascript code for BasemapGallery into separate custom widgets. I going to use a lot of layers and I don't want to clutter up the main javascript file.Essentially, I just wrapped the same code that would go in the map web map HTML and javascript into a widget package call customWidget.BasemapGalleryI was successful in making creating a TitlePane that opens up to a BaseMapGallery but that's as far as I went. Whenever I click on a image of a map. The main map doesn't change.Here is my code.JAVASCRIPT portion of the main map
app.map = new esri.Map(
"mapDiv",
center: [-64.46968730, 45.08473950], //Kentville, Nova Scotia, Canada
zoom: 13,
logo: false,
showAttribution: false,
slider: true,
sliderStyle: "large",
basemap: "streets"
HTML of the widget: BasemapGallery.html[HTML]<div class="${baseClass}"> <div> <div id="baseMapGalleryTitlePane"> <div data-dojo-type="dijit.layout.ContentPane" style="width:380px; height:280px; overflow:auto;"> <div id="basemapGalleryDiv" ></div> </div> </div> </div></div>[/HTML]JAVASCRIPT of the widget: BasemapGallery.js
dojo.provide("customWidget.BasemapGallery");
//required library imports from esri
dojo.require("esri.dijit.Basemap");
dojo.require("esri.dijit.BasemapLayer");
dojo.require("esri.dijit.BasemapGallery");
//required library imports from dojo
dojo.require("dijit._Widget");
dojo.require("dijit._Templated");
dojo.require("dijit.TitlePane");
dojo.require("dijit.layout.ContentPane");
dojo.declare("customWidget.BasemapGallery", [dijit._Widget, dijit._Templated], {
templateString: dojo.cache('customWidget.BasemapGallery', 'templates/BasemapGallery.html'),
baseClass: "BasemapGalleryBase",
title: "",
postCreate: function(){
* add basemap basemapgallery widget.
* need to be the same extent
createBasemapGallery();
// build the basemap gallery
function createBasemapGallery(){
var tp = new dijit.TitlePane(
title:'Switch Basemap',
closable:false,
open:false
dojo.byId("baseMapGalleryTitlePane")
var map = dojo.byId("mapDiv");
var basemapGallery = new esri.dijit.BasemapGallery(
bingMapKey: "AnwMNXxXUVsOh1xEmG_i6D_ajxScpoxwwXQHTdOjBM5NcPzXsxhxkVU6dq_Hr4Gw",
map: map,
showArcGISBasemaps: true
"basemapGalleryDiv"
//basemapGallery.basemaps = basemaps;
basemapGallery.startup();
HELP HELP.
