Attribute Assistant Update Linked Record Value Method
4442
14
05-24-2013 01:04 PM
ZachLawson
My office maintains a point feature class of all of our force main air release valves and a separate table with all the maintenance/inspections/etc done on these ARVs. What I want to happen is when a new maintenance item (a new row) is added to my ARV_Maintenance table, the Last_Inspection_Date field of my ARV feature class is updated with the date from the Inspection_Date field of the new row. It seems that UPDATE_LINKED_RECORD should do what I want, but I can't get it to work. I'm currently trying (and some variations thereof):
Table Name: ARV_Maintenance
Field Name: Inspection_Date
Value Method: UPDATE_LINKED_RECORD
Value Info: ARV|Last_Inspection_Date|Unique_ID|Unique_ID
What am I missing here?
JohnathanLaughery
I'm having the same issue. Did you ever resolve your issue?
JustinFlannery3
I'm attempting to do something very similar and have been unable to get this method to work.
MikeMillerGIS
Esri Frequent Contributor
Can you enable the Attribute Assistant log file, it will help us troubleshoot the issue.
JustinFlannery3
Edit Log Started at: 10/12/2017 8:41:17 AM
Attribute Assistant start editing
Process Count: 0
Unwiring the events
Inspection - ON_CHANGE
Starting AA
############ 10/12/2017 8:41:37 AM ################
Setting sort order: Field - RUNORDER
Querying table for Last Value for layer: Inspection
Query Used: (TABLENAME = '*' OR TABLENAME = 'Inspection' OR TABLENAME like 'Inspection|*' OR TABLENAME like 'Inspection|%') AND VALUEMETHOD = 'Last_Value'
Number of results: 0
Querying table for rules for layer: Inspection
Query Used: (TABLENAME = '*' OR TABLENAME = 'Inspection' OR TABLENAME like 'Inspection|*' OR TABLENAME like 'Inspection|%') AND ON_CHANGE = 1
Number of results: 1
Looping through the rows
Row Info
Row Number 1
TableName: Inspection
FieldName: DATE
ValueInfo: BMP|LAST_INSPECTED|BMP_ID|BMP_ID
ValueMethod: UPDATE_LINKED_RECORD
On Create: 1
On Change: 1
Checking for Subtype Restriction
Field Name: DATE was found at index: 2
Trying: UPDATE_LINKED_RECORD
Getting Value Info
Checking values
Checking Field in Edited Layer
Checking for related record
Trying to Copy Value to the Record
ERROR: Could not Copy: 10/13/2017 12:00:00 AM to field: LAST_INSPECTED
Related record not found.
Finished: UPDATE_LINKED_RECORD
DONE
Wiring the events
Attribute Assistant is being suspended
Attribute Assistant is being turn off
Closing Log File 10/12/2017 8:41:54 AM
Edit:  DATE and LAST_INSPECTED are both date fields.  I'm using a file geodatabase.
MikeMillerGIS
Looks like a bug trying to copy a date value.  Any chance you could send me a sample set of data so I can create a repo case?
JustinFlannery3
Absolutely.  I have only been testing a few things so I could send a copy of the entire geodatabase if you'd like.  What is the best way to send the file?
MikeMillerGIS
email is good, will try to look today - mmiller@esri.com
MikeMillerGIS
Justin, what version of the tools are you using?  Your data worked fine for me.  I changed the date of a record in the inspection table and that value was set in the parent BMP.
JustinFlannery3
I am on ArcMap 10.4.1 and the Add-In Manager tells me that my Attribute Assistant version is 6.26.2015.
