Problems creating an MXD thumbnail.
3224
05-30-2013 09:45 AM
PrestonMcCormick
I would like to create a thumbnail for a map document, but I've run into problems.  I've found two avenues of aproach, but neither works well.
Method 1 opens the MXD with the MapDocumentClass and then saves using IMapDocument.Save(useRelativePaths, createThumbnail).  This method works for simple map documents.  But, any map layers with a transparency setting will not show in the thumbnail.  Their labels will show, but not the features.  For the maps I'm working with, this results in an unrecognizable thumbnail.
Method 2 uses IDocumentPreview.CreatePreview method off of an MxDocumentClass retrieved from the currently open map document in ArcMap.  This method used to work in ArcMap 9 (as long as the document already had a thumbnail).  It does not seem to work in ArcMap 10.  I have tried setting the IDocumentInfo.SavePreview flag to true and flagging the document as dirty before save, but nothing results in a thumbnail saved with the MXD.
I think it should be possible to get this to work, since the CreateThumbnail button in the Map Document Properties dialog works.  Does anyone have some working code?
by Anonymous User
Not applicable
I don't have any working cod, but I ran the following script and had problems.  Every map document in the folder reverted back to 8 1/2 x 11 inch page sizes targeted to my default printer.  I lost all my large-format printer settings and had to reposition and resize every element in the layout view, causing me to redo hours of work done over the last few days.  Yes, I should have tried with only one map document as a test, but it's a hard less to relearn.
import os
import os.path
import arcpy.mapping
mapFolder = os.curdir
for mapDoc in os.listdir(mapFolder):
    if os.path.splitext(mapDoc)[1] == '.mxd':
        mapPath = os.path.join(mapFolder, mapDoc)
        print 'Regenerating thumbnail for ' + mapPath + '...'
        mxd = arcpy.mapping.MapDocument(mapPath)
        mxd.deleteThumbnail()
        mxd.makeThumbnail()
        mxd.save()
        del mxd
