Clear Data Frame Projection
4690
8
06-12-2013 01:27 PM
PatrickYoung
How would I use Python to clear the data frame projection in ArcMap?
Patrick
ChrisSnyder
Regular Contributor III
This should theoretically do it:
undefinedSr = arcpy.SpatialReference() #Note this DOES NOT make a 'Unknown' SR obj, see below
mxd = r"C:\temp\my_mxd.mxd"
for df in arcpy.mapping.ListDataFrames(mxd):
   df.spatialReference = undefinedSr
mxd.save()
del mxd
However, I found this is actually a bit more difficult.... The trick is to get a SR object to be of a "Unknown" coordinate system. The only way I could do this was to run the DefineProjection tool, and manually clear out the 'Coordinate System' parameter - which makes its value then default to a magic value called Unknown (note this is NOT a string value of "Unknown", but something else). Once I had a FC defined with an Unknown SR, then:
undefinedSr = arcpy.Describe(unknownSrFC).spatialReference
mxd.save()
del mxd
Which worked...
Anyone know a better way to create an Unknown spatial reference object?
Tried all these, which do not work:
undefinedSr = arcpy.SpatialReference(None)
undefinedSr = arcpy.SpatialReference(0)
undefinedSr = arcpy.SpatialReference("Unknown")
undefinedSr = arcpy.SpatialReference(Unknown)
Seems like there should be a EPSG code for Unknown/Undefined, but I can't find it...
ShaunWalbridge
try this:
sr = arcpy.SpatialReference()
sr = sr.loadFromString('{B286C06B-0879-11D2-AACA-00C04FA33C20}')
That should create a proper 'unknown' spatial reference object. Source bug report.
ChrisSnyder
>>> unknownSr = arcpy.SpatialReference()
>>> unknownSr.loadFromString('{B286C06B-0879-11D2-AACA-00C04FA33C20}')
>>> unknownSr.name
'Unknown'
Works great!
Nothing says Unknown coordinate system like '{B286C06B-0879-11D2-AACA-00C04FA33C20}'...
ShaunWalbridge
Yes, I agree. You can pull out these class ID values from the bin/XMLSupport.dat file within your installation directory, but it'd be nice to have a 'named' way to create an unknown coordinate system. I've submitted an enhancement request on the problem.
JonPedder
Occasional Contributor II
Thanks for this info, though I'm having an issue with this as it doesn't appear to play well with arcpy.DefineProjection_management(p,newSpatialReference).
newSpatialReference = arcpy.SpatialReference()
newSpatialReference = newSpatialReference.loadFromString('{B286C06B-0879-11D2-AACA-00C04FA33C20}')
def clearSR():
    # Copy FC's to the new database
    dsList = arcpy.ListDatasets()
    fcList = arcpy.ListFeatureClasses()
    projectList = dsList + fcList
    # Project the datasets and featureclasses and write to target db
    for p in projectList:
        arcpy.AddMessage('Defining Spatial Reference for {0}'.format(p))
Jon
JoeZhou1
arcpy.DefineProjection_management(p,newSpatialReference)  ”
This is error in arcgis 10.
ExecuteError: ERROR 000622: Failed to execute (Define Projection). Parameters are not valid.
ERROR 000628: Cannot set input into parameter coor_system.
ShaunWalbridge
Jon and Joe,​
The reason your code doesn't work is your second line:
This is setting newSpatialReference to the return value of the loadFromString function.
But loadFromString doesn't return anything, it sets the calling object value, so you have a None value
for the rest of your script, which Define projection doesn't like. To unset projection, just call loadFromString:
That will create the object, then assign the value with loadFromString. I tested it and it works fine with DefineProjection.
Cheers,
Shaun
JoeZhou1
Test OK!
Thank you very much!
