Mosaic raster files in a loop from all sub-directories in a directory
4562
5
06-24-2013 01:58 PM
ZiaAhmed
New Contributor III
I am trying to mosaic all tif files from a directory, it works fine for the files for a particular directory using following python code. I like to run this code in a loop to process data  for all other months (~/year/month/date). Structure of my input dir, sub directories like this:
L:/MODIS_NDVI/TIF_files/2001/ January /Date_01
~  /Date_02
L:/MODIS_NDVI/TIF_files/2001/ February /Date_01
~  /Date_02
Help will be appreciated.
Zia
# Mosaic:  Date 01, January, 2001
try:
    import arcpy
    arcpy.env.workspace =  r"L:/MODIS_NDVI/TIF_files/2001/ January /Date_01"
    rasterList = arcpy.ListRasters("*","TIF")
    outLoc = "H:\\ MODIS_NDVI \\MOSAIC_Files \\2001\\January\\"+ raster[9:-16]
    arcpy.MosaicToNewRaster_management(rasterList, outLoc + ".tif", "", "16_BIT_SIGNED", "", "1", "LAST", "FIRST")
except:
    print "Mosiac failed."
    print arcpy.GetMessages()
#  Mosaic : Date 02, January, 2001
try:
    import arcpy
    arcpy.env.workspace =  r"L:/MODIS_NDVI/TIF_files/2001/ January /Date_02"
except:
RhettZufelt
MVP Frequent Contributor
Glad I could help.
If you get a chance, could you click the checkmark in the upper right of the post that answered your question.
This will give me credit for it.
R_
RhettZufelt
Would probably read the years, months, and dates into their own list.
import arcpy, os
years = []
months = []    ##  either populate these manually or read in
dates = []
try:
    for year in years:
       for month in months:
          for date in dates:
             workspace = arcpy.env.workspace = r"L:\MODIS_NDVI\TIF_files" + os.sep + year + os.sep + month + os.sep + date
             outLoc = workspace + os.sep + "mosaic.tif"
             arcpy.MosaicToNewRaster_management(rasterList, outLoc, "", "16_BIT_SIGNED", "", "1", "LAST", "FIRST")
except:
Have not tried this, nor am I anywhere that I can but should make a new mosaic.tif file in each date folder with all the tiff files from that folder mosaiced.
R_
ZiaAhmed
New Contributor III
Thank you so much. After slight modification, following  code works fine when all files have organized  according to month (sub-folder) and dates (sub-sub-folder) in year directory.
If all files are one folder (for example - year_2001 folder), is it possible to apply python function in a loop - that will  mosaic files for a individual date (julian date - like 2001001- for January 1, 2001) one after another?   My study location is covered by two MODIS sheets (h25v06 and h26V06).  File names,  for example are 2001001.h25v06.tif, 2001001.h26v06, 2001017,h25v06, 2001017,h26v06 ......
Thanks again for helping me.
ZIa
import arcpy, os
months = ['01_Jan','02_Feb']
dates = ['Date_01','Date_02']
Fn=''
    for date in dates:
        try:
            workspace = arcpy.env.workspace = r"M:\BD_MODIS_NDVI\PROJ_TIF\Test" + os.sep + month + os.sep + date+ os.sep
            for raster in rasterList:
                Fn= raster[0:7] # file names
            arcpy.MosaicToNewRaster_management(rasterList,workspace, Fn+".tif","", "16_BIT_SIGNED", "", "1", "LAST", "FIRST")
        except:
RhettZufelt
Could try something like this:
import arcpy, os
rasts = []
try:
     workspace = arcpy.env.workspace = r"L:/MODIS_NDVI/TIF_files/2001"
         rasts.append(raster.split(".")[0])    ## grabs the filename before first "." which is J year and appends to the list "rasts"
         del raster
     rastSet = set(rasts)            ## make a set so unique (no duplicates) - result of one entry for each julian year
     for r in rastSet:                  ##iterate through set
         newList = []
         for raster in rasterList:         ## iterate through list of rasters again, and those that start with our value for r are appended to NewList.
             if raster.startswith(r):
                 newList.append(raster)   ## use this newList as you raster list for mosaic tool
         want to do the mosaic at this indentation level so it only does it for r = singlevalue
         del raster
         del newList
except:
That should get you going,
R_
ZiaAhmed
New Contributor III
Thank you so much. It mosaic files accordingly. I appreciate your help. It save lot of my time. Here is the final code:
# Mosaic.py
# Created on: 2013-03-02 17:51:39.00000
# Description:
import arcpy, os
Fn=''
rasts = []
try:
         del raster
     for r in rastSet:
         newList = []
                 for raster in newList:
                 arcpy.MosaicToNewRaster_management(newList,workspace, Fn+".tif","", "16_BIT_SIGNED", "", "1", "LAST", "FIRST")
         # want to do the mosaic at this indentation level so it only does it for r = singlevalue
         del raster
         del newList
except:
import arcpy, os
rasts = []
try:
         del raster
         newList = []
         del raster
         del newList
except:
R_
RhettZufelt
Glad I could help.
R_
