Issue with publishing a Feature Service
12516
72
07-03-2013 06:14 AM
MatthesRieke
Hi all,
I have been trying to publish a hosted Feature Service based on a local data frame using ArcMap 10.1's "Share As/Service" feature (following the tutorial at http://resources.arcgis.com/en/help/arcgisonline/index.html#//010q00000087000000 ). Though, the service appears in "My Contents" (as a Service Definition, is that correct?) it is not published or accesible in any way (I have been trying to access it from GeoEvent Processor Beta). When I try to publish it manually (through the Item view's "Publish" button), I get an error message "Invalid tenant Id Invalid tenant login".
Publishing the same local data frame to my own ArcGIS Server 10.1 instance works. The TileService for the same data frame works as well. I am currently using the 30-day trial subscription, could this be an issue?
Thanks in advance,
Matthes
MikeMinami
Esri Notable Contributor
Thanks for reporting this. We are aware of this issue and it seems to be related to newly started subscriptions. Did you just sign up for your trial? We are working to resolve this and push the fix out.
Mike
MatthesRieke
Hi Mike,
thanks for your quick response. Yes indeed, I signed up for the trial this tuesday.
Kind regards,
Matthes
AlbertoAloe
Hi everybody
I have exactly the same issue. I cannot publish a feature service from ArcMap 10.1. I see a service definition but when I try to publish it I get that message.....
Alberto
MatthesRieke
for me this works now. Maybe the fix is user-dependent?
AlbertoAloe
I think so. I'll e-mail ESRI support.
Alberto
fredfred1
how long it takes before the publication of entity service is functional once you create a tria account?
MikeMinami
You should be able to publish services right away once you've activated the subscription.
Mike
fredfred1
Thanks for replying Mike,
but till now, it didn't seems to work for me and I get the following message "Invalid tenant Id Invalid tenant login" every time when I try to publish a feature service.
I just created my trial account ArcGIS Online and I can upload shape files in my content but I can't create feature services
MikeMinami
When did you create your trial subscription?
Mike
