Trying to edit a layer in a versioned SDE GDB in a Python stand-alone script
6172
10
07-17-2013 12:47 PM
JaimeMcKeown
Hello everyone,
I am trying to do a simple edit using Calculate field on a layer in a versioned SDE GDB. I've gotten past a few errors, but now have ran into a new one that I can seem to get past. The error is "Objects in this class cannot be updated outside an edit session". I'm trying to use arcpy.da.Editor, but I seem to be missing something.  Any ideas would be greatly appreciated!
fc = "Database Connections\\CCENTGIS_SCLFinal_PRSCL_test.sde\\prscl_test.SCLADMIN.GMSCL\\prscl_test.SCLADMIN.sclarc" workspace = "Database Connections\\CCENTGIS_SCLFinal_PRSCL_test.sde"  arcpy.MakeFeatureLayer_management(fc, "sclarc_layer")  edit = arcpy.da.Editor(workspace)  edit.startEditing() edit.startOperation()  with arcpy.da.Editor(workspace) as edit:     arcpy.CalculateField_management("sclarc_layer", "STRNAME", "!strname!.strip", "PYTHON_9.3", "")  edit.stopOperation() edit.stopEditing(True)
MathewCoyle
Can you post your code you are running again? The only lines you should need are these
import arcpy workspace = "Database Connections\\CCENTGIS_SCLFinal_PRSCL_test.sde\\prscl_test.SCLADMIN.GMSCL" fc = "prscl_test.SCLADMIN.sclarc" arcpy.env.workspace = workspace arcpy.MakeFeatureLayer_management(fc, "sclarc_layer") with arcpy.da.Editor(workspace) as edit:     arcpy.CalculateField_management("sclarc_layer", "STRNAME", "!strname!.strip", "PYTHON_9.3", "")
MathewCoyle
I believe you need to set your workspace to your feature dataset, not the general database.
JaimeMcKeown
When I set the workspace to the dataset I get "runtime error: cannot open workspace".
MathewCoyle
Are you connected with a version user that can make edits?
JaimeMcKeown
I'm trying to edit a test version of the database, and it turns out it wasn't setup properly.  Now that's fixed and I can edit, but it still won't run properly.
This is my latest error:
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 326, in RunScript
    exec codeObject in __main__.__dict__
  File "G:\prscl\appl\Python\Scl_qcarcs_test.py", line 20, in <module>
AttributeError: 'Workspace Operation object' object has no attribute 'stopOperation'
MathewCoyle
Ah yes you'll have to have those inside your with statement as afterwards your edit variable is closed automatically.
JaimeMcKeown
I moved edit.stopOperation() and edit.stopEditing() into the statement and I still get the same error.  I'm beginning to think this isn't going to work...
MathewCoyle
Have you tried removing those lines completely? The help examples shows just the with statement as able to stop and close the edit session automatically.
http://resources.arcgis.com/en/help/main/10.1/index.html#//018w00000005000000
            layer_name, 'Usage', '"PUBLIC"', 'PYTHON')
JaimeMcKeown
I did and it still doesn't work, very frustrating...
MathewCoyle
