archydro for ArcGIS 10.2?
22472
27
08-05-2013 12:12 PM
BradleyNeish1
Does anyone know if/when a new version of archydro will be released for the new 10.2 platform?
ChristineDartiguenave
I just posted Arc Hydro 10.2 on the ftp site.
Christine
Christine Dartiguenave
Esri Water Resources Team
V_StuartFoote
MVP Frequent Contributor
Bradley,
Asked, and received a note back from Christine D., they are working on it already...
"You need a specific installation package for 10.2.
We created one so far using the same code base and found some issues
(so far raster processing was ok but we need some code changes for some of the raster to vector
and vectors function (e.g. catchment))... it is not ready yet."
So keep an eye out in this forum, you'll know about it pretty quickly once released to the sftp site.
Stuart
Christine
BradleyNeish1
Awesome, thank you. Installed and seems to be working great.
V_StuartFoote
@Esri Water Resources Team,
Installed ArcHydro 10.2.0.6  for ArcGIS 10.2 using the 64-bit geoprocessing based build. Clean install with nothing amiss on review of a verbose install log.
Cursory testing has everything functioning as expected.
Thanks!
Stuart
TeresaArrospide
Christine
Where can I find the new version of Arc Hydro tools that are compatible with ArcGIS 10.2 ?
Teresa
V_StuartFoote
Teresa,
Open the secure ftp site as in this thread, and navigate to:
/incoming/ArcHydro/Setup10.2
Stuart
V_StuartFoote
New-password-for-Arc-Hydro-ftp-site-October-1st-2013
Note -- it is set Sticky and top posted in the ArcHydro forum.
Stuart
It got moved by mistake under another folder. It is back where it should be.
DavidButman
Is anyone getting errors regarding the Apframework required for Archydro 10.2 install?  The install package requires ApFramework 10.2.0.6 which I cannot seem to find anywhere.  Please help,
David
