My end goal is to use a TimeSlider and cycle through a number of rasters in a catalog (raster of same area that changes over time)... but after much tinkering with the time aware settings, I realized my rasters in the catalog won???t show at all (using time or not). I have since removed the time settings from both the map and the Silverlight app and can't get the rasters to show. It DOES show up in the JavaScript API.
Things I have tried:
- Removed all time settings
- Filtered out to one single raster
- Changed symbology (was classified, now stretched)
- Removed all other layers from the map
- Published both MXD and MSD (I think one time, early on I got it to display the first raster from an MXD in the time series)
- Create v10 Mosaic from the catalog, but I don't have the Image Server Extension for the 10 Pre-Release... plus I it looks like I would have to reformat all the dates to do a time aware if published as an Image Service (would prefer to just keep them in the catalog for now)
Also, the raster catalog is in a File Geodatabase which the layer points to via a UNC path.
Any help and ideas would be great! Thanks a lot!
*EDIT* It seems that any service with a raster (even pointing to a file based sid) doesn't work... it actually seems to prevent the rest of the feature layers from drawing too. Is it running out of some temp cache space or something???
