Unfederate Server
9594
09-11-2013 02:21 AM
shreyesshiv
New Contributor III
I log in to my administrator account on Portal for ArcGIS
click on My Organization->Edit Settings->Servers
In the servers list there is a server which was federated with the Portal previously.
At present when I want to Remove server from the Portal, it throws me an error saying
"Unable to update the authentication tier of the server prior to unregistering it from the portal. The server has not been changed or unregistered."
That server never gets removed and even when I try to over write it by adding it as a new server it shows This server is already registered in ArcGIS Portal.
I even changed the Authentication tier as ArcGIS Server at Security->Config
Is there is a solution for this?
RaviNarayanan
Hi Shreyes,
A couple of things to check.
1. The serverUrl or the admin url that is registered with the portal may be invalid.  When unfederating use fiddler or firebug to check the request that is failing.
2. the servers security settings may have been changed and it is no longer federated with portal.  If the serverInfo resource (http://serverurl/arcgis/rest/info?f=pjson) reports a owningSystemUrl property, that would indicate the server is federated with this portal listed in the owningSystemUrl.
you can manually unfederate the server by following these two steps.
1. sign into portal api (portalurl/arcgis/sharing/rest) as a portal admin
2. go to http://portalurl/arcgis/sharing/rest/portals/self/servers and click on the server that should be unregistered and unregister the server.
3. Sign into ArcGIS Server Manager (http://serverurl/arcgis/manager) and change the security settings back to arcgis server authentication.
shreyesshiv
New Contributor III
Hi Shreyes,
Thanks Ravi your post was of great help and it worked like a charm
WenfengLi
New Contributor III
This is very helpful. I had a federated server to the portal. Which is corrupted, I could not remove or unfederate it. This is exactly the way to unregister the server.
DennisGeasan
Occasional Contributor II
That process works but you may also have to return to the federated server and reset the AGS authentication to "GIS_Server" .
