The log for database 'ReportServer$SQLEXPRESS' is not available. Check the event log for related error messages. Resolve any errors and restart the database.. In the last 40 minutes this error message appears 16 times, the time intervals are not regularly spaced. When the geodatabase is throwing the connection error the log will say the same thing except change ReportServer with my database name.
Solved! Go to Solution.
Address Windowing Extensions (AWE) requires the 'lock pages in memory' privilege which is not currently present in the access token of the process.
