Bug in ArcGISFeatureLayer.getField(String fieldName)?
3689
10-03-2013 07:41 AM
JasonKnisley
I was writing a program where I needed to check properties of various fields, and so I decided to use the ArcGISFeatureLayer.getField(String fieldName) but kept experiencing errors. The return value was always null. So as a quick test, I did this...
final ArcGISFeatureLayer testLayer = new ArcGISFeatureLayer(
    "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSFields/FeatureServer/0",
    MODE.SNAPSHOT);
testLayer.setOnStatusChangedListener(new OnStatusChangedListener() {
    private static final long serialVersionUID = 1L;
    public void onStatusChanged(Object arg0, STATUS arg1) {
        if (arg1 == STATUS.INITIALIZED) {
            Field[] fields = testLayer.getFields();
            Log.d(TAG, featureLayer.getName() + ": found " + fields.length + " fields");
            boolean found = false;
            for (Field field : fields) {
                if (testLayer.getField(field.getName()) != null) {
                    Log.d(TAG, featureLayer.getName() + ": found field object for " + field.getName());
                    found = true;
            if (!found) {
                Log.d(TAG, featureLayer.getName() + ": no field objects found by name");
Which results in
!! Current Kansas Field Production: found 23 fields
!! Current Kansas Field Production: no field object found by name
Why does getField(fieldName) always return null?
MengyiGuo
I tested the code and seems it works on ArcGIS Runtime SDK for Android 10.2.5. I noticed it has been a while so I'm not sure if you still have the issue. Besides, it seems that your layer variable name is testLayer but when you log it, the layer variable name is featureLayer.
Please test the following code and let me know if it works:
final ArcGISFeatureLayer testLayer = new ArcGISFeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSFields/FeatureServer/0", ArcGISFeatureLayer.MODE.SNAPSHOT);
                    Log.d(TAG, testLayer.getName() + ": found " + fields.length + " fields");
                            Log.d(TAG, testLayer.getName() + ": found field object for " + field.getName());
                            found = true;
                    if (!found) {
                        Log.d(TAG, testLayer.getName() + ": no field objects found by name");
I got the following outputs:
02-19 11:35:51.207    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found 23 fields
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for objectid
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for field_kid
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for approxacre
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for field_name
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for status
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for prod_gas
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for prod_oil
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for activeprod
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for cumm_oil
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for maxoilwell
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for lastoilpro
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for lastoilwel
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for lastodate
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for cumm_gas
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for maxgaswell
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for lastgaspro
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for lastgaswel
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for lastgdate
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for avgdepth
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for avgdepthsl
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for polydate
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for field_type
02-19 11:35:51.208    6837-6837/com.arcgis.android.samples.maps.helloworld D/Test!!﹕ Current Kansas Field Production: found field object for field_kidn
