Hi allwhat is the difference between webmap and appid in the basic viewer?Where do I find these values? webmap: null,
// webmap: "dbd1c6d52f4e447f8c01d14a691a70fe",
//Modify this to point to your sharing service URL if you are using the portal
sharingurl: "http://www.arcgis.com",
//sharingurl: null,//for example: "http://www.arcgis.com",
//The id for the web mapping application item that contains configuration info - in most
////When editing you need to specify a proxyurl (see below) if the service is on a different domain
//Specify a proxy url if you will be editing, using the elevation profile or have secure services or web maps that are not shared with everyone.
proxyurl: "",
//cases this will be null.
appid: "8746539d974c4f2c808d8d32582b100b",
//appid: "",
