Anyone else experiencing trouble with the print widget in Flex 3.1 this morning? Any of my services fail when trying to print. Below is the error I receive...
Hi Chad, All of my production Flex Viewers version 3.0 are blowing up when the users try to print. I get the Server.Error.Request error. faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]. URL: http://sampleserver6.arcgisonline.com/ArcGIS/rest/services/Utilities/PrintingTools/GPServer/Export%2...Layout%5FTemplate=Letter%20ANSI%20A%20Landscape&f=json&Format=PDF&Web%5FMap%5Fas%5FJSON=%7B%22layoutOptions%22%3A%7B%22legendOptions%22% and etc. I thought it was just us. Thanks for putting this out there. Thanks, Janie
Both of you should not be using esris sample server services if you have your own ArcGIS Server 10.x that has a print service running. Esri does not recommend the use of sample servers in a production environment.
