Conditional Domains
4546
7
10-15-2013 03:28 AM
MarkYoung
Hi all,
Does anyone know if it is possible to have 'conditional' domains. For example a value of commercial in field1 would spawn a domain in the next field of C1 C2 C3 etc whereas a value of residential in field1 would spawn a domain with R1 R2 R3 etc..
Mark
MarcoBoeringa
MVP Regular Contributor
Hi all,
Mark
Yes, this is possible. In order to do this, you need to create subtypes. See the following Help pages:
A quick tour of subtypes
Working with subtypes
MarcoBoeringa
Hi all,
Mark
MarkYoung
Thanks - I now have a sub type (field2) based on field1
I tried to create a second sub type (field3) based on field2 but it will only let me base it on field1 - is it possible to create a sub type of a sub type?
Mark
MarcoBoeringa
To be honest, I have never used subtypes in real-life, so its getting a bit theoretical here, but I am pretty sure subtypes can't be "nested". So you will have to adjust your geodatabase design to accommodate for this limitation. E.g. by creating separate Feature Classes for the different fields you want subtypes on.
MarkYoung
Thinking that as well.. What I might do is link to an excel spreadsheet and create the nested sub types there - see if that works,
Thank you for  your help with this anyway.
Mark
MatthewGerber3
I am interested on this same topic.  It is something I am able to do in Excel which is called dependent drop downs and was want to extend this to GIS databases.  (Pipelines can be made of particular material, then each material is constructed to particular standards, and each standard has only certain sizes available)
But taking Mark's same example and rewording it.
Say you have the following fields:
- Landuse
- Density
- Structure Type
Landuse = Residential, Commercial, Industry
Density (For Residential) = Low, Medium or High
Density (For Commercial) = Services, Offices
Density (For Industry) = Light, Heavy, Hi-Tech
Structure type (for Residential - Low) = Single Dwelling, Acerage
Structure type (for Residential - Medium) = Townhouse, Duplex
Structure type (for Residential - High) = Units, High Rise, Hotel
Structure type (for Commercial - Services) = Automotive, Retail, Health
Structure type (for Commercial - Offices) = Finance, Resources,Government
Structure type (for Industry - Light) = Agricultural
Structure type (for Industry - Heavy) = Mining, Manufacturing
Structure type (for Industry - Hi-Tech) = Medical equipment, Computer manufacturing
And for these fields you would like only valid domains to be displayed in the drop downs as you go along the attribute table.
eg.
I choose landuse = residential
I only want Density - low, medium,high to be displayed in the drop down box.
Then when I choose Medium... I only want structure type = townhouse or duplex to be displayed in that attributes drop down box.
Hope that clears up Mike's question
AnninaHirschi_Wyss1
Occasional Contributor III
Hi mgerbz‌, Did you find out something how to do this? Would be very interested in that possibility too...
MatthewGerber3
Hi a.hirschi-wyssesri-rw-esridist‌, No i did not.  I got the short answer of, It is not able to be done in a standard geodatabse setup / by ESRI software parameters.   I have a theory that in the SQL/Oracle RDMS geodatabase world, you could expose this type of methodology into an enterprise geodatabase.  However have not progressed on this any further.
