WebTiledLayer in BasemapGallery
5366
7
10-20-2013 10:11 PM
RaivoAlla
Hello!
My intention is to add custom basemaps (WebTiledLayer) to BasemapGallery, without ArcGISBasemaps, in the following way:
                        var bm1 = BasemapLayer({type: "WebTiledLayer",url:"http://tiles.maaamet.ee/tm/s/1.0.0/kaart/${level}/${col}/${row}.png"});
   var bm2 = BasemapLayer({type: "WebTiledLayer",url:"http://tiles.maaamet.ee/tm/s/1.0.0/hybriid/${level}/${col}/${row}.png"});
   var akaart = new Basemap({
    layers: [ bm1, bm2 ],
     title: "MAMT aluskaart 1 "
   var hkaart = new Basemap({
    layers: [ bm2 ],
     title: "MAMT aluskaart 2"
   basemaps = [akaart, hkaart];
          basemapDijit = new BasemapGallery({
     basemaps: basemaps,
     showArcGISBasemaps: false,
     //basemapsGroup: basemapGroup,
     map: _self.options.map
    },domConstruct.create("div"));
Somehow it is not possible and digging deeper into ArcGIS JSAPI I found that the the function _switchBasemapLayers outputs:
"esri.dijit.BasemapGallery: Unable to switch basemap because new basemap is a tiled service and cannot be loaded as a dynamic layer." (this.map.getNumLevels() returns 0).
Yet the API (https://developers.arcgis.com/en/javascript/jsapi/basemaplayer.html) says that it's possible to add WebTiledLayer as a BasemapLayer and hence I assume it's possible to add as a Basemap to BasemapGallery.
What's the problem here? I would appreciate any help.
Thank you,
Raivo Alla
Estonian Land Board
AbhijatC
New Contributor III
Hello!
    layers: [ bm2 ],
     basemaps: basemaps,
Thank you,
Raivo Alla
Estonian Land Board
Raivo,
I think you should use "basemaps.push(akaart);" & "basemaps.push(hkaart);" instead of "basemaps = [akaart, hkaart];".
I used the example and feature layer (mentioned by you as http://tiles.maaamet.ee/tm/s/1.0.0/hybriid/1/1/1.png and it worked perfectly.
Look at this edited code:
function createBasemapGallery() {
      //manually create basemaps to add to basemap gallery
      var basemaps = [];
      var waterTemplateLayer = new esri.dijit.BasemapLayer({type:"WebTiledLayer",
        url:"http://tiles.maaamet.ee/tm/s/1.0.0/hybriid/1/1/1.png"
      var waterBasemap = new esri.dijit.Basemap({
        layers      :[waterTemplateLayer],
        title       :"Water Template"
      basemaps.push(waterBasemap);
Abhy
RaivoAlla
Thanks, Abhy!
Actually I had it declared in a "basemaps.push" style before. The thing is, that it is all perfectly working in my own javascript code, but not in the template: neither in the SocialMedia web application template, nor in the application boilerplate template.
Maybe it is a coordinate sytem issue (I have EPSG:3301 defined for the map, tile service is also in EPSG:3301). Maybe it has something to with the "map" object being not referred correctly?
In the boilerplate case, the main code resides in main.js, where, in the _createWebMap I get response.map object to work with. An I have defined my createbasemapgallery code inside the "if(this.map.loaded) {"section. But no luck.
Gallery appears, but when clicking the gallery node, I get to know, that this.map.getNumLevels() in BasemapGallery.js _switchBasemapLayers is 0 and hence can't add basemap layers on the map...
Huh,
Raivo
RaivoAlla
I have been (again) hitting the ArcGIS JS wall... and it seems to be unbreakable at some spots.
Now it seems that I cannot add BaseMapLayer(that "contains" WebTiledLayer) into the BasemapGallery AFTER I have created the mapo object via arcgisUtils.createMap.
I mean, yes I can get the response.map object and work with it, but I seem not to be able to define the LOD since
1. my ArcGIS Online webmap has no cached service (I use custom WMS as a basemap there)
2. I found no way to attach my basemapgallery onto that map object so it can use those BasemapLayers as a basemap.
The esri.Map interface shows setBasemap method that is only possible with Esri-accepted basemap layers.
I feel being locked into small chamber, but I sense out there is lots of space and freedom.
The one and most important question for me: is it possible to use WebTiledLayer in BasemapGallery or not when working with Esri
boilerplate templates?
Thank you,
Raivo Alla
Estonian Land Board
AbhijatC
New Contributor III
Thank you,
Raivo Alla
Estonian Land Board
Hey Raivo,
I checked for the "Social Media Template"...Fortunately all worked fine there too. What I changed look at code below:
// create the basemap gallery when active
        createBMGallery: function() {
            var _self = this;
   var basemaps=[];
            var basemapGroup = false;
            if (!_self.options.useArcGISOnlineBasemaps) {
                basemapGroup = {
                    title: _self.options.basemapGroupTitle,
                    owner: _self.options.basemapGroupOwner
            // basemap gallery
            _self.basemapDijit = new BasemapGallery({
                showArcGISBasemaps: _self.options.useArcGISOnlineBasemaps,
                basemaps: basemaps,
            }, domConstruct.create("div"));
In addition to above code, I also changed the options in the config (NOT commonConfig) file as:
"useArcGISOnlineBasemaps": false,
Check out the attachments.
Hope it helps,
Abhy
RaivoAlla
Thanks Abhy,
but I have no success here. It doesn't even trigger the onLoad function there:
connect.connect(_self.basemapDijit, "onLoad", function() {
  console.log("im in!");
But as soon as I set "showArcGISBasemaps: true" in BasemapGallery contruction, the onload function fires correctly.
Raivo
RaivoAlla
To elaborate the issue once more, the problem seems to be - as it is stated almost 3 years ago in http://forums.arcgis.com/threads/85123-WebTiledLayer-doesn-t-work-with-BasemapGallery-dijit?highligh... - BasemapGallery does not fully support custom WebTiledLayers, even if it claims so (https://developers.arcgis.com/en/javascript/jsapi/basemaplayer.html : "Must specify either the url or type parameter except for WebTiledLayers where url and type is required. (Added at v3.7)").
However, I will get my basemaps in SocialMedia map when my referenced webmap has some ArcGIS basemap defined. But, as soon asI use my custom basemap (WMS service added with "use as a basemap" option), this functionality vanishes...
So, summing it up - it appears to be a bug (or a businness stragtegy?).
Thank you,
Raivo Alla
Estonian Lond Board
KevinWells2
I found a way to get WebTileLayers to work in the BasemapGallery widget. It is not an elegant solution but it worked for me.
When creating the "Map" widget I assigned one of ESRI's standard basemaps as the basemap (i.e. basemap: "gray") even though in the BasemapGallery widget the showArcGISBasemaps is set to false. This crazy scenario allowed the WebTileLayers I had in the BasemapGallery to work.
var map = new Map('mapDiv', {
     basemap: 'gray'
var basemapGallery = new BasemapGallery({
     basemaps: basemaps,                   <<< The WebTileLayers added as basemaps.
     map: map,
}, 'basemapGallery');
When the map loads I switch the basemap to the WebTileLayer I want to use and set the visibility of ESRI's basemap to false.
map.on('load', function() {
     basemapGallery.select('Lite');                          <  Select the WebTileLayer I wanted all along.
     map.getLayer('layer1').setVisibility(false);      <  Hide the esri basemap.
The map and web tile layers all used the Web Mercator projection. The ArcGIS JavaScript version was 3.16.
