Changing the default units of the measurement widget?
3131
10-29-2013 01:03 PM
IanPeebles
Occasional Contributor III
I have a measurement widget within my application.  When measuring, the default is set as Miles.  Can I change the default units to Feet?  Also, the default for measuring areas is set to Acres. . I need to default to Sq Feet.
Thanks.
JoshVan_Kylen
New Contributor III
Set the defaultLengthUnit to esriFeet and the defaultAreaUnit to esriSquareFeet.
Example:
          measurement = new Measurement({
              map: map, defaultLengthUnit: "esriFeet", defaultAreaUnit: "esriSquareFeet"
          }, dom.byId('measurementDiv'));
          measurement.startup();
RickeyFight
MVP Regular Contributor
Ian,
Look here for more documentation:
Measurement | API Reference | ArcGIS API for JavaScript
JoshVan_Kylen
New Contributor III
What I found unclear about this Measurement | API Reference | ArcGIS API for JavaScript documentation is that it references this Object: Units page, but when I used just "FEET" & "SQUARE_FEET" in the Measurement's parameters I get errors.  Hunting around I found the reference to set the parameter values to esriFeet & esriSquareFeet in the
Web AppBuilder's API reference for the Measurement widget.
