This class works:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Collections.Specialized;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Net;
using System.Windows.Forms;
using System.Net.Http;
using System.Net.Http.Headers;
using System.IO;
using System.Runtime.Serialization.Json;
using System.Web;
using System.IdentityModel.Tokens;
using System.Xml;
namespace GeocodeForm
public class AGOL
private string _token;
private string _username;
private string _password;
public organizationInformation orgInfo;
public string GetAGOLToken(string UserName, string PassWord)
_username = UserName;
_password = PassWord;
_token = GetToken(UserName, PassWord);
orgInfo = _getOrgInfo(_token);
MessageBox.Show(orgInfo.availableCredits.ToString(), "Available Credits", MessageBoxButtons.OK);
return _token;
public organizationInformation _getOrgInfo(string token)
var data = new NameValueCollection();
data["token"] = token;
data["f"] = "json";
organizationInformation x = Deserialize<organizationInformation>(_getResponse(data, "http://www.arcgis.com/sharing/rest/portals/self"));
return x;
private static T Deserialize<T>(string json)
var instance = Activator.CreateInstance<T>();
using (MemoryStream ms = new MemoryStream(System.Text.Encoding.Unicode.GetBytes(json)))
DataContractJsonSerializer serializer = new DataContractJsonSerializer(instance.GetType());
return (T)serializer.ReadObject(ms);
private string _getResponse(NameValueCollection data, string url)
string responseData;
var webClient = new WebClient();
var response = webClient.UploadValues(url, data);
// Get the response.
responseData = System.Text.Encoding.UTF8.GetString(response);
return responseData;
public string GetToken(string username, string password)
data["username"] = username;
data["password"] = password;
data["referer"] = "https://www.arcgis.com";
data["f"] = "json";
var jssD = new System.Web.Script.Serialization.JavaScriptSerializer();
TokenInfo x = jssD.Deserialize<TokenInfo>(_getResponse(data, "https://arcgis.com/sharing/rest/generateToken"));
string jeff = x.token.ToString();
return x.token;
public class TokenInfo
public string token { get; set; }
public long expires { get; set; }
public bool ssl { get; set; }
public class organizationInformation
public string access { get; set; }
public bool allSSL { get; set; }
public double availableCredits { get; set; }
public string backgroundImage { get; set; }
public string basemapGalleryGroupQuery { get; set; }
public string bingKey { get; set; }
public bool canListApps { get; set; }
public bool canListData { get; set; }
public bool canListPreProvisionedItems { get; set; }
public bool canProvisionDirectPurchase { get; set; }
public bool canSearchPublic { get; set; }
public bool canShareBingPublic { get; set; }
public bool canSharePublic { get; set; }
public bool canSignInArcGIS { get; set; }
public bool canSignInIDP { get; set; }
public string colorSetsGroupQuery { get; set; }
public bool commentsEnabled { get; set; }
public long created { get; set; }
public string culture { get; set; }
public string customBaseUrl { get; set; }
public int databaseQuota { get; set; }
public int databaseUsage { get; set; }
public string description { get; set; }
public string featuredGroupsId { get; set; }
public string featuredItemsGroupQuery { get; set; }
public string galleryTemplatesGroupQuery { get; set; }
public string helpBase { get; set; }
public string homePageFeaturedContent { get; set; }
public int homePageFeaturedContentCount { get; set; }
public int httpPort { get; set; }
public int httpsPort { get; set; }
public string id { get; set; }
public string ipCntryCode { get; set; }
public bool isPortal { get; set; }
public string layerTemplatesGroupQuery { get; set; }
public int maxTokenExpirationMinutes { get; set; }
public long modified { get; set; }
public string name { get; set; }
public string portalHostname { get; set; }
public string portalMode { get; set; }
public string portalName { get; set; }
public object portalThumbnail { get; set; }
public string region { get; set; }
public bool showHomePageDescription { get; set; }
public string staticImagesUrl { get; set; }
public long storageQuota { get; set; }
public long storageUsage { get; set; }
public bool supportsHostedServices { get; set; }
public bool supportsOAuth { get; set; }
public string symbolSetsGroupQuery { get; set; }
public string templatesGroupQuery { get; set; }
public string thumbnail { get; set; }
public string units { get; set; }
public string urlKey { get; set; }
public bool useStandardizedQuery { get; set; }
} // end class
