Hello Jose, did you manage to solve the problem?
I'm trying to modify the loaded.config so the tools will work with my own model, but i'm a bit lost....
Hi Marcela,
I was able to configure it. the config file (Loaded.config) is located in different folders following your operating system
Configure Attribute Assistant - Water Utility Network Editing | ArcGIS for Local Government
Operating System | Directory |
Windows Vista, 7, and 8 | C:\Users\%UserName%\AppData\Roaming\ArcGISSolutions\ConfigFiles |
Windows Server 2008 | C:\Users\%UserName%\AppData\Roaming\ArcGISSolutions\ConfigFiles |
Windows XP | C:\Documents and Settings\%UserName%\Application Data\ArcGISSolutions\ConfigFiles |
Windows Server 2003 | C:\Documents and Settings\%UserName%\Application Data\ArcGISSolutions\ConfigFiles |
Jose, i've been abre to open the file, it's just that i'm not sure what to modify in the file, i don't know if i have to use the feature class name or it's alias. can you attach your modified file so i can take a look at it or post a screen shot?
thanks!
Hi Marcela,
You need to use the feature class name
For example feature class Sewer Manholes (SManhole) has a field called Municipality ID (MUNICID) and gets populated with the value of the municipality polygon when it gets digitized.
OBJECTID | TABLENAME | FIELDNAME | VALUEMETHOD | VALUEINFO | ON_CREATE | ON_CHANGE | ON_CHANGEGEO | ON_MANUAL | RUN_WEIGHT | COMMENTS |
218 | SManhole | MUNICID | INTERSECTING_FEATURE | Municipality_poly|MUNICID | 1 | 0 | 1 | 0 | 3 |
