Publishing geoprocessing service takes forver
2865
12-27-2013 12:38 PM
ShawnCarson
New Contributor III
Here is an odd one. I am trying to publish a geoprocessing service (a python script). It published without issues last week. Lately however when I try and re-publish, it takes over 30 minutes to publish. After much digging around I found the slowness  to be attributed to the following two lines at the top of my python script:
import os
import uuid
In test cases I remove these lines and the service publishes in 5 seconds. When I include these lines it takes 30 minutes...
The script in toolbox always runs fast, its just when I try and publish as a service is when it gets slow.
I don't know what I did (if anything) to cause this slowness. I even re-installed Desktop and Server and its still slow when I use the above import statements.
Does anyone know of anything I can do  to get the service to find the libraries quickly when publishing teh service?
Maybe I can set the path to these libraries explicitly so the service isn't  looking around forever?
Thanks for any ideas.
Shawn
WilliamCraft
MVP Regular Contributor
Interesting.  You might first try adding each of those two lines separately and re-attempting service publishing to see if it's one of them specifically that's causing issues or if it's both of them.
ShawnCarson
New Contributor III
Good test. Thanks for the suggestion. I did that and either library causes the issue. Importing  arcpy by itself creates the service quickly. I think it must be something to do with any python libraries, earlier I was having issues with running python in ArcGIS so I set my environment variables which fixed that issue but may have causes this new problem.
ShawnCarson
New Contributor III
I solved this by removing all references to my PYTHONPATH variables in Environment Variables-->System Variables (?) . The service isnow created in 10 seconds.
I am not sure how python is being "found" without any of these variables being set but python is working using IDLE,  PyScripter,  and within ArcGIS.
